  3. Track Talk
  4. Lexan fitment.
Lexan fitment.
16 Posts 6 Posters 3.2k Views
  • mx6phanM Offline
    mx6phanM Offline
    mx6phan
    Has anyone installed a windsheild or rear window using a flat sheet of polycarb.? I am going to replace my front and rear window and am concerned that I wont beable to get the compound curves neccesarry for it to look as close to factory as possible. So if anyone has any tips or tricks to doing this it would be great.
    Earl Stanley MSN- [email protected]
    93 Mazda MX-6 2.0 13.6@104mph (9psi) Daily Driver
    94 Ford Probe GT (new project)
      Heat gun...and work SLOWLY.
      • mx6phanM Offline
        mx6phanM Offline
        mx6phan
        So is this an easy project with patience, or easily screwed up?
        Aslo, with 3/16 will I need to run a center brace with a 60" wide windsheild?
          We put 3/16" in Matts car and it doesn't need a brace. I put the same stuff in mine and it doesn't appear to need a brace either, but we'll see once it's at speed.
          As for making the bends, all we did was screw the piece to the frame and it took on the shape needed automatically. You can kinda see the shape through the dirt in this pic.
          • mx6phanM Offline
            mx6phanM Offline
            mx6phan
            Thanks Dave. Didnt carck or nothing when you pre-drilled the holes?
              I'll let dave tell his story about whether it cracked or not....
              To make it bend easier (and minimize your odds at cracking) I still stand by my idea of warming (not melting) the lexan as you screw it in. To minimize the odds of cracking when drilling, I'd recommend applying duct tape to BOTH sides of the lexan before drilling AND using a lubicant (WD-40) when drilling through. Maybe I'm overcautious, but thats the method I've used and seen others use when working with Acylic/Lexan/etc...
                Just get good lexan, don't get the crap from Menards, etc. The Menard crap cracked as I was trying to cut it, and cracked again as I was trying to screw it onto the frame. 😛
                I got good polycarb from Custom Plastics in North Fargo, we just pre-drilled the holes and screwed it down.
                • mx6phanM Offline
                  mx6phanM Offline
                  mx6phan
                  what did that run for price. The stuff I'm looking at in jegs will run me about 180 per window. 36x60
                  Plus I'm sure you or Matt would be more than willing to help. 🙂 Actually I could have Matt's brother help. Offer is on the table for help though.
                  • 9 Offline
                    9 Offline
                    91psiTSI
                    MX6phan thanks for starting this thread i have been wondering the same stuff. I want to put lexan in my talon and i was just curious on how much it ran you guys (matt,Dave). Any helpful info would help me out as well!
                    • ColinC Offline
                      ColinC Offline
                      Colin
                      Is lexan really a choice for DD?? I would think it would discolour in sun and the streaks from rocks etc... just wondering
                      • fallguyF Offline
                        fallguyF Offline
                        fallguy
                        Just measure what you need and call Custom Plastics for the price. It wasn't that bad really. Price depends on the quality of poly you want. You can by scratch resistant stuff, but it's double of regular poly.
                        Good luck!
                        1990 Ford Probe GT 2jz RWD
                          I might be able to source some poly as well...I can find out if you want.
                            For good polycarbonate, 3/16" front and 1/8" for the sides it cost me ~$250 for the front windshield and the two doors.
                            • 9 Offline
                              9 Offline
                              91psiTSI
                              How easy was it to cut to shape and what tools did you use?
                              • mx6phanM Offline
                                mx6phanM Offline
                                mx6phan
                                250 for the doors and windows aint bad. So probly around 350 or so including the rear window too.
                                BTW, the car isnt gonna be much of a DD any more. Just barely legal enough to take the ocasional drive.
                                • fallguyF Offline
                                  fallguyF Offline
                                  fallguy
                                  You make a template out of card board or poster board and they cut it all for you. 🙂
