  4. mini me
mini me
12 Posts 6 Posters 1.2k Views
  • H Offline
    H Offline
    hondacivicchris
    i have a 93 civic that i did a mini me swap on. but when ever the v-tec should kick in it loads up and theres nothing there. if you dont let up on the gas it will back fire. if any one knows whays could be wrong let me know . also used a d15 jdm v-tec sil and the dizzy that came on the car d15 non v-tec
    • karter_2_22K Offline
      karter_2_22
      i believe you need a -** dizzy, could be wrong
        Yeah, you need a **** dizzy.
        • H Offline
          H Offline
          hondacivicchris
          thanks i'll try to find one
          • darkelvisD Offline
            darkelvisD Offline
            darkelvis
            no you don't. The VEETACH dizzy is just so it's bolts line up properly, if you have a dizzy on there you are good. What you need is the proper ecu. 🙂
            • H Offline
              H Offline
              hondacivicchris
              i have a p 28
                as far as i know Z6 dizzies and Y8 dizzies are different in their pattern...IDK if the B7 one is different or not...
                Anyway, i'd try getting a Z6 dizzy first...you throwin any CEL's?...if my dizzy was still wired for obd1 i'd meet ya up somewhere and let you try it out to see...but it's been rewired for obd2.
                • H Offline
                  H Offline
                  hondacivicchris
                  k i'll try to find a dizzy
                  • no_slow_clapN Offline
                    no_slow_clap
                    the d15v tec heads are the same as d16z6 heads. and it wouldnt matter if you used the dizzy off the b7 the only thing thats different is the pattern.
                    EVOLUTION VIII
                      darkelvisD Offline
                      darkelvis
                      You need the right ecu!
                      • H Offline
                        H Offline
                        hondacivicchris
                        what ecu should i get
                        • H Offline
                          H Offline
                          hondacivicchris
                          have p28
