  4. turbo integra???
turbo integra???
6 Posts 4 Posters 869 Views
  • GnArKiLlG
    GnArKiLlG
    GnArKiLl
    my friend and i are turboing his integra b18a1 with a mitsu 16g and i need to know where i can tap into for coolent and oil. also where can i get vac line from to go to the bov?.. lmk any help on this would be great!!
    1976 Chevy K5- lifted beater
    • inspector01I
      inspector01I
      Oil should be right on the back near the filter, pull out a plug. And vac, use any spot on the intake mani and either disconnect something or run a T-line.
      • itsthelaserI
        itsthelaserI
        itsthelaser
        you need to get an oil filter adapter plate and you can run the oil out of there and you can also order a vacuum log from golden eagle with about 5 vacuum hose connectors...dont know how much its cheap though......not sure....ur only gna wanna run aobut 5-7 pounds on that old DA anyways so i wouldnt worry about coolant right now.....jus have him get an oil feed only t28 or go old skool with a potato disc turbo....call me tomarow and well talk sum more
        It has INTAKE???HEADER???EXHAUST????......wow gotta have it....thats jus AFTERMARKET WONDERFUL
        • integra_gsr98I
          integra_gsr98I
          potato disc turbo? HAHAHAAHAHAHA.
          Honestly, don't waste your time with a 16g.
          http://www.straightlinespecialties.com/ for all of your turbo honda needs. We've got em figured out. 😉
          • GnArKiLlG
            GnArKiLlG
            GnArKiLl
            we just had a 16g layin around so thats what we are gonna use.. but im sure he will go bigger over time..
            • integra_gsr98I
              integra_gsr98I
              Do it right the first time is the only advice I can give you.
              "If you can't do it right the first time, how will you be able to afford to do it a second time?"
