  4. Car Audio Equipment FS
7 Posts 1 Posters 869 Views
    PHOENIX GOLD R9.0:5 4x125W+1x400W OCTANE-R AMPLIFIER
    The all-new Octane-R Series Amplifiers are big-power amplifiers with street racing cosmetics. Overbuilt and indestructible power supplies provide rock solid stability and reliability. Phoenix Gold took a look at what's happening on the streets and came out with a new line of amps that have all the answers. Not just another pretty face (but they ARE beautiful!), these new amps can also take anything you can throw at them. Count on Phoenix Gold's engineers to deliver the goods. Features: *Fully complementary output stage *5 channel power amplifier *400 watt sub channel!
    Specifications: *Power output, front and rear stereo channels: 50 watts RMS/125 watts max x 4 (4 ohm load), 75 watts RMS/200 watts max x 4 (2 ohm load), 150 watts RMS x 2 (bridged mono, 4 ohm load) *Power output, mono subwoofer channel: 150 watts RMS/250 watts max x 1 (4 ohm load), 250 watts RMS/400 watts max x 1 (2 ohm load) *Frequency response: 20 Hz-20 kHz *THD 1% *Signal to noise ratio: greater than 110 dB *Dimensions: 19.75" L x 10.875" W x 2.25" H. - Carbon fiber badge, backlit with blue LED
    • Optional neon inserts for all amp models
    • Overload and comparator circuitry
    • Remote Monitoring Display (RMD) port, remote sold separately
    • Two/four channel amplifiers stability = 2 ohms stereo/4 ohms bridged
    • Full-range thru output
    • Twin
    • 12 dB Low pass continuously variable crossover (40-400 Hz
      Used for 2 seasons but has less than 100 hours of use on it. Works great. Only reason I am replacing it is because I no longer sell Phoenix Gold equipment.
    **$175 obo NEW PRICE
    **[COLOR=Black]Phoenix Gold ZR10D4 10" subwoofers
    [/COLOR][SIZE=1]OCTANE-ZR SUBWOOFER SPECS:[/SIZE] • Injection molded aluminum plated grained polypropylene cone • 3 peice injection molded dust cap with aluminum plating • Carbon fiber inlay and blue LED backlight • Computer optimized large bumped motor assembly • Large roll butyl rubber surround • Injection molded rubber motor housing • Integrated rubber mounting gasket • 2 inch high temperature voice coil • 30mm Peak to Peak excursion • Cast aluminum basket
    **$50 each (I have 1 pair) obo
        **OCTANE-ZR                                         6.5 COMP
    **• Injection molded aluminum plated grained polypropylene cone • Butyl rubber surround • Flat linear roll spider • 25mm silk dome tweeter • External 24dB/octave acoustic crossover
    $100 obo [B] SOLD
    [/B]
        **OCTANE-R                                         5.0c COAX
    • 5.25 inch (130mm) Coaxial
    • Frequency response: 90Hz-20kHz
    • Sensitivity: 89dB (1W/1M)**
    [COLOR=Red]$30 obo[/COLOR]
    Chuck Schwan
    701-541-3484
      bump....all this MUST GO! No reasonable offer refused
        Bump, 6.5" components are sold
          Amp tentatively sold!
            everything is sold now except the 5.25" speakers and the subs.
              Bump again...also have clarion 4" coaxials (used one season) and a pair of sub boxes that are a direct drop in to a wrx (10")
                Everything has now sold except for the 5.25" PG Coax's and the Clarion 4" Coaxials.
