Still boggin down...
blindsp1;163727 wrote:
with the test pipe the check engine light was on..then i cleared it about 3 months ago and it hasent come on since.....but i need to find a stock cat for cheap first...because the test pipe doesnt do anything anyway..or just get turbo back 3 inch exhaust.....
with the test pipe the check engine light was on..then i cleared it about 3 months ago and it hasent come on since.....but i need to find a stock cat for cheap first...because the test pipe doesnt do anything anyway..The cat is not the root of your problems. From what Frank was saying you have your BOV duct taped on and you hacked up the stock plastic IC pipe to make it all fit up. For starters, fix that setup right and move on from there.
MisterCMK;163722 wrote:
I believe that the ECU requires the O2 sensor to switch between .7 or whatever and 0 otherwise it will set a codenot the downstream 02. the down stream 02 usually doesnt change its voltage much. it doesnt switch from 0-1 v like the upstream 02.
It wasent me who hacked it....beaner did...he said he did that to lacey's gst and said it worked... -
blindsp1;163734 wrote:
It wasent me who hacked it....beaner did...he said he did that to lacey's gst and said it worked...Wow, i wouldn't check first to possibly be a problem..........
DON'T DO MODS IF YOU AREN'T GOING TO DO THEM AT LEAST 1/2 RIGHT. Seriously, is it worth stupid shit like this just to have a louder bov.
ic you on newcelica jim lol, RadeonX... random. anyways, yes his current intake and bov setup is very ghetto didn't get a chance to check for any leaks today though, to busy working on zachs swap. how easy is it going to be to tell if there is a leak, need any tools or is it just run your hand over the piping and feel for air?
if its held on by duct tape it leaks...
Slowica;163759 wrote:
ic you on newcelica jim lol, RadeonX... random. anyways, yes his current intake and bov setup is very ghetto didn't get a chance to check for any leaks today though, to busy working on zachs swap. how easy is it going to be to tell if there is a leak, need any tools or is it just run your hand over the piping and feel for air?What about me and newcelica? huh?
you can buy a hardpiping kit on ebay for like $120 shipped....buy one
