slightly bigger turbo
Look on dsmtuner classifieds. I'd go so far as to say that you'd be just as happy with a 14b as with a 16g. The 16g will have a little slower spool up but won't run out of steam quite as fast as the 14b, but then again to max out a 16g you'll need some significant fuel mods. I'm rocking the 14b and after porting the exhaust side and o2 housing it spools up very nicely and the powerband is from around 2500-5500 which is nice for around town. I have the boost down to around 12-14 psi still from the winter, but before that I was running 17psi with just a fuel pump (wally 190, and then 3000gt pump, the 190 was loud) and ecu remapping. Im sure I could have done better with some dyno time to fine tune my fuel map (Logging pulls on country roads isn't really accurate) but my car was quick as shit at 17psi with a 14b.
You'll need basically the same stuff you'd need for any turbo swap. The difference is that with the 14b you can find everything you need used on dsmtuners.com and for a nice price. Plus there is ALOT of info as hundreds of people have done the 14b swap on thier 2gs. Theres prolly even a VFAQ on it somewhere.
I think you'll need either a new manifold or at least a new flange, the stock 2g flange for a t25 won't work with any of the mitsu turbos. aside from that, you'll need a boost controller (manual is easiest), a boost gauge, and a 14b turbo, o2 sensor housing, and you'll prolly need something to adapt your exhaust since the stock downpipe prolly won't fit the new o2 housing. I'd suggest going to DSMTUNERS.com and signing up for the forums and reading the info there. It's not hard at all so don't worry. -
Jim;167478 wrote:
except more then 1/2 of the 14b's you'll find are shot or will be soon after... i had a 14b on my 2g, it was fun, but if i could do it over again, i'd get a b16g w/ external gate + fmic and be done with itExcept didn't he say he didn't want to spend that much money? A new b16g, external gate, manifold w/ flange and welded internal w/g, fmic w/ piping, + additional supporting mods needed over the basic 14b setup is a pretty serious chunk of change amirite?
As far as finding good turbos, I got lucky and found a rebuilt one complete with actuator and o2 housing for a song, and never had a problem with it. Its a matter of having the patience to look around, and the luck not to get ripped off vs. the price of a brand new setup.
I'm a friggen expert at finding good used parts and tuning on a budget if I do say so myself. Most, if not all of the mods on my car are preowned and are working very well. If you need help finding something I'd be glad to lend a hand.
wait wait wait... hold on jest a sec. i completley failed to read the thread. I think I saw you say that you are doing this because people are 'telling you to upgrade'??? so you haven't yet squished the potential out of that t25 yet? and you don't have an exhaust? okey nevermind everything I just said, stop worrying about impressing your boyfriends, and start tuning your damn car. Better yet, give your car to me, and get something better, you need an upgrade!!
Why would you need a new manifold w/ flange? But yeah, of course the cheap way to go is just a 14b keeping the stock sidemount w/ a J pipe etc...
I was just saying in terms of how much fun, and how much the car will break, if I could do it over again, I'd opt for a b16g w/ the external gate (get rid of those creepin problems) and supporting mods, and shoot for an area between 300-350whp and call it a day.
Anyway, yeah, exhaust is what you need, not a new turbo.
but an external gate is really the way to go for fine boost control.
