  4. Timing
Timing
16 Posts 5 Posters 1.5k Views
  • integra_gsr98I
    integra_gsr98I
    yes.
    • integra_gsr98I
      integra_gsr98I
      replace anything timing belt related, especially since your last one broke.
      1. timing belt
      2. water pump
      3. timing belt tensioner
      4. might as well do a new A/C belt and P/S belt.
      • 94_dsm_nt9
        94_dsm_nt9
        94_dsm_nt
        Can I get the timing belt on without taking off the crank pulley?
        1987 Mustang GT
        New Toy: 1976 F-100 4x4, 10 inches of lift, 390 with Edelbrock Performer intake, Holley double pumper, 4:50 gears, front and rear lockers, 38x15x15 Super Swampers. :icon_thumright: :D
        • integra_gsr98I
          integra_gsr98I
          No.
          • 94_dsm_nt9
            94_dsm_nt9
            94_dsm_nt
            What's the best way to get the crank pulley off, if i don't have an impact wrench? I'm trying to get this done on the cheap side. I don't want to take it to a shop if I don't have to.
            1987 Mustang GT
            • integra_gsr98I
              integra_gsr98I
              use an impact wrench or buy the $150 crank pulley holder from mac tools. 🙂
              • 94_dsm_nt9
                94_dsm_nt9
                94_dsm_nt
                Could I just have someone hold the brakes on while I take it off?
                1987 Mustang GT
                • 94_dsm_nt9
                  94_dsm_nt9
                  94_dsm_nt
                  Well I now have the timing belt on and it turns over fine, but it doesn't fire. I checked all the fuses and what not, but everyone looked just fine. I am officially stumped now.:icon_scratch:
                  1987 Mustang GT
                  • integra_gsr98I
                    integra_gsr98I
                    Does it have spark? Good compression? Timing belt off? Everything plugged in?
                    • 94_dsm_nt9
                      94_dsm_nt9
                      94_dsm_nt
                      Everything looks good. Is the #1 cylinder the first one on the drivers side?
                      1987 Mustang GT
                      • sleepermaximaS
                        sleepermaximaS
                        sleepermaxima
                        yes. If you are standing in front of the car the order from left to right should be 4-3-2-1.
                        checking compression at this point would be pretty important. setting the cam gear off by a couple teeth will cause you trouble. A compression test will tell you if you are off. If you find out that you are off then fix it and still don't get compression you may have bent the valves.
                        Also, quadruple-check your spark plug wires IF you happened to take them off the distributor during the job. I always found a way to screw that up. Firing order should be 1-3-4-2. The rotor runs clockwise and #1 pin should be located at the upper-left for SOHC motors, otherwise, it's lower left I believe.
                        2003 Honda VTX 1800 C
                        • bubbaB
                          bubbaB
                          I know of one kid that had one and one day something happend to it and would start, they thought the motor was toast and I think it was just the timing was off 180 degrees.
                          • 94_dsm_nt9
                            94_dsm_nt9
                            94_dsm_nt
                            Well idk if I need to have a battery hooked up to it, because all I've done is hook up my jumper cables from my Oldsmobile.
                            1987 Mustang GT
