  4. Big problem....No turbos
39 Posts 12 Posters 1.7k Views
  • z31Z Offline
    z31Z Offline
    z31
    KA-T_240;170899 wrote:
    did they even make TT z31s?
    That is correct, unless it is a 7/89, that would make it a 1990
    • JN210J Offline
      JN210J Offline
      JN210
      well what's mine then? all i know is its a 89 300ZX N/A
      *1989 Nissan 300ZX Z31 *
      > DelSlow;262050 wrote:
      > I like the new JN210
      • z31Z Offline
        z31Z Offline
        z31
        does it have pop up head lites?
        • z31Z Offline
          z31Z Offline
          z31
          JN210;170884 wrote:
          Ok so ive looked just about everywhere i can for a turbo or two for my 89 300ZX but can't find one. Does anyone know where i could find a whole twin turbo kit for it?Is it a z31 (84-89) or is it a z32 (90-96) This would be very helpful. There is no "turbo kit". for these cars.
            It's a Z31. You could use factory parts to make it a stock style setup.
              ^what he said. you could of corse do a custom setup, but that would cost a lot fo $$$$$.
              • z31Z Offline
                z31Z Offline
                z31
                You'r in luck, I am the master of the z31.
                  Yes, you are the person to talk to about them.
                  • JN210J Offline
                    JN210J Offline
                    JN210
                    so how would this "custom" setup work?
                    • JN607J Offline
                      JN607J Offline
                      JN607
                      You'd need everything from a TT ECU, exhuast manifolds, oil feed lines, intercooler with piping etc etc etc...Trust me buddy, your best bet is to just drive it the way that it is, and later on down the road, buy something better...Unless you still want to talk about dropping in an SR20 or maybe, if it fits, an RB26...granted that engine would cost as much as your entire car...
                      And Z31, it IS a Z31...89 NA Z31...AUTOMATIC if I may add...
                      2004 Scion xA
                      Airman First Class Nelson
                        an RB would probably work.
                        Have you thought about the vg30dett out of a z32?
                          IMO i'd do a full engine swap to a stock turbo one, it'd be safer and more reliable that way. I know people that have done NA -> TII swaps in FC's and they turned out great.
                          • JN607J Offline
                            JN607J Offline
                            JN607
                            The Z32 engine is huge compared to the Z31 engine that's in there. There would be so many clearance issues. That would be like me trying to put a 6G72TT in the venge...Just to big. I say RB26 All the way...
                            2004 Scion xA
                              RB25s are cheap. Be ready to weld and wire...
                                actually those cars could be had with a RB25 in them in jap land and aussie-land. As far as ding a turbo swap, its alot more work than it seems. you are best off finding a complete car, just sold one in wahp for $300, you missed out big on that one. You need:
                                front crossmember
                                motor mounts
                                driver side exhaust mani
                                turbo and elbow
                                downpipe
                                oil pan/ feed line
                                charge pipe
                                ECU
                                and if you swap to a 5-speed, the trans and a driveshaft
                                shifter and console
                                cluth pedal and master cyl
                                OR
                                complete rusted out stock Z31 turbo car
                                Honestly it turns out to be alot of work, and your best bet is pulling the motor and assembling everything on it. Also i would not look for a turbo engine swap, as they are 7.8:1 compression, and are absolutely dead off boost. while you have it apart, throw the stock T3 in the trash and pick up a 50 trim or 60 trim, just need the exhaust housing for the stock turbo machined out.
                                If you are interested in doing the swap, im sure Z31 and I would be happy to do the work for some cash.
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  And thats all for an RB25 or 26? and whenever i have the money to do that i am definately going to do it.
                                  • JN607J Offline
                                    JN607J Offline
                                    JN607
                                    Yeah, except for the fact that you don't exactly have a super high paying job...if this were something you wanted to do, you are going to need to start putting money away out of your paycheck...
                                    2004 Scion xA
                                    • JN210J Offline
                                      JN210J Offline
                                      JN210
                                      Yes that's true and i have been putting away money. I know it aint cheap.
                                        no, thats everything you need to convert your VG30E to a VG30ET. your looking at substantially more to convert to a RB25, just keep dreaming about doing that. like i said, best bet is find a really shitty 84-88 z31 turbo 5 speed, wrecked, rusted so you can see through it, whatever. long as its $500 or less. start stripping parts off of it and get em cleaned up. To swap everything onto your motor your looking at probably 40 hours labor to do it the right way, thats switching to a 5-speed as well. add in the cost of new gaskets, timing belt if you havent done it lately, O2 sensor, clutch etc. if you arent doing it yourself, make sure you have at least $1500 saved up, plus the donor car. If you do it yourself, figure in about $500-$1000 in extra parts. Plus the cost of a new turbo or rebuilding the stock t3/t25.
                                        Gary
                                        • JN210J Offline
                                          JN210J Offline
                                          JN210
                                          Well that looks like alot of work but im definately wanting it done so im willing to do that, where would be a good place to start lookin for a POS Z31? In other words what are the local junkyards?
