  3. ICE and Detailing
  4. indash tv
indash tv
16 Posts 4 Posters 2.1k Views
    tjamz;172248 wrote:
    Depends 100% on the brand of the DVD player. Some require 3-4 steps to ensure that the ebrake is in fact hooked up properly and the car isn't moving (alpine pops in my head for this), so grounding the wire won't do anything for you. Clarion requires the wire to see ground/open/ground before you can watch a movie on the screen, JVC is straight up ground, can't remember what Kenwood requires.... At any rate, check what conditions need to happen for the deck to operate properly. That will tell you if the deck can be just grounded, or if you have to tie into the ebrake or if you have to tie into ebrake and the brake light. As for the dash light being on, that means nothing to the dvd player, you will still have to connect to the ebrake (if the ebrake needs to be switched off/on...) wire.
    thats exaclty what i said in my first post....most of the older ones you can just hook up to a ground wire..atleast all the ones i've hooked up..but alot of the newer models theres different things you have to do.
      I know...I was just clarifying.
      • killer69penguinK Offline
        killer69penguin
        hey thanks a lot and just curious most likely i am leaning towards a pioneer any idea on how those work off the top of your head?
        1993 3000GT VR4
          every pioneer i've installed is just a ground.
            I take it you haven't installed one in a while John? The AVIC series almost all have a series of things you need to do to bypass them. With some you can cheat and put the deck into "Demo" mode by flipping a switch on the bottom of the deck, but a lot of the new ones with navigation also use the vehicle speed sensor wire to determine if the car is moving...good luck bypassing that AND having the navigation work...
            Basically, let us know EXACTLY which model you are working with and we can offer advice on how to bypass it.
            Also, is there any particular reason you are thinking Pioneer? They are nice, but overpriced if you buy them from a legit source...and most online places are not legit and offer no manufacturers warranty.
              I guess the only AVIC series i've installed is the N1 and that was the first one out and didnt require anything so thats probably why..
              but yeah i agree theres lots of better brands out there for your $$.
              although i've never been a fan of pioneer at all
                killer69penguin
                i guess the model im looking at is AVIC-N2 i believe but i dont know a ton about them any other suggestions
                1993 3000GT VR4
                  The common bypass for the N2 is to peal back the silver sticker on the bottom of the unit and either
                  A) Change the position of the dipswitch (if equiped w/ dipswitch)
                  -or-
                  B) Solder between the two points under the sticker (if not equiped with dipswitch)
                  Both options will void your warranty on the spot.
                    killer69penguin
                    you got any other units or brands you would suggest that dont run to terriblie expensive?
                    1993 3000GT VR4
                      sending a PM
