  4. Mounting Harness's
Mounting Harness's
18 Posts 6 Posters 689 Views
  • DWeigsD Offline
    DWeigsD Offline
    DWeigs
    If i were to get a 3 point harness where would that mount???
    • ColinC Offline
      ColinC Offline
      Colin
      I'm pretty sure people on this board have been fined for using harnesses instead of seatbelts.
        I've been pulled over and never had issues using harnesses. Although at the same time, my harnesses were mounted to a cage inside the vehicle, haha.
          integra_gsr98;172585 wrote:
          You will be fine using harnesses as seatbelts, and the police will not hassle you. However I would recommend a harness bar. SLS would be able to build you one that would be bolted to the top portion where your stock seatbelts used to go, with a mounting tab for your seatbelts. You can also purchase them from some places as well.
          Seatbelts are in the door on that model, so I dont think u could mount the harnesses in the stock location, if it was an 88 or 89 hf or dx they have pillar mounted belts and you could attach the harnesses to that, my friend has something like that in his ek coupe. I have been wondering this as well, I would like to get some harnesses someday for my car.
            Ahh in that case you would have to weld a plate to the b pillars behind the plastic, and then cut and notch the plastic around a permanent harness bar. I'd probably just find stock seatbelts.
              I just remembered that I have a set of doors (kinda rusted so u probably dont want the whole door) that'll work with the seatbelts in them. But if you want the seatbelts out of them lmk and we can work something out.
              • DWeigsD Offline
                DWeigsD Offline
                DWeigs
                I might have to do that... I was looking at a few harness bars off of ebay for 200 bucks.... Maybe i can get my mom to just buy that for me until i get more money...
                • hondaking424H Offline
                  hondaking424
                  y dont u just hit up ebay and get some stock seatbelst for cheap?
                  • DWeigsD Offline
                    DWeigsD Offline
                    DWeigs
                    Because it would be easier to just get the harness bar or find a way to hook up the harness's without the bar
                    • DWeigsD Offline
                      DWeigsD Offline
                      DWeigs
                      By looking over the instructions again... I came to the conclusion that I will be able to mount them to the back frame... So thanks for the help everyone... Ill post some pics when they are done!!
