  4. Painting an engine bay
23 Posts 15 Posters 980 Views
    what color is the car now? i think black bays look pretty clean with the right outside color.
    • ColinC Offline
      ColinC Offline
      Colin
      RidinRails;172721 wrote:
      yes its rice
      thats funny from the guy with a coffee can coming off the back of his car 😛
      Again: performance oriented. ONLY WONDERING ABOUT THE HEAT REFLECTING/ABSORBING QUALITIES OF BLACK PAINT
      • ErikE Offline
        ErikE Offline
        Erik
        I can only think that heat issues would be light/sunlight affected. So an engine bay should really have no effect.
        Except for glowing exhaust manifolds.
        They call me, old man...
        • thurmanmermanT Offline
          thurmanmerman
          Ive seen guys paint it gray so they can tell if they are leaking any fluids easier. Im sure black spray paint won't have any affect on it at all. If it was like a high temp heat resistant paint then thats a different story.
          > Parker;299126 wrote:
          • black2gB Offline
            black2gB Offline
            black2g
            i've heard painting a block a certain color is bad for heat but the engine bay shouldn't matter.
            1995 Eagle Talon
            2000 Doge Neon
            1974 Porsche 914
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              Black is naturally a better absorber of radiant heat than other colors. So...I guess it will help you out some by absorbing some of the engine bay heat and conducting it through your body panels to then be convected into the ambient air.
                Ive seen a lot of ppl with theirs black so i would assume it should be all good. are you going to remove some of the holes in the bay to by welding them and grinding them smooth too? it gives it that real clean look.
                • ColinC Offline
                  ColinC Offline
                  Colin
                  I'm not into "clean" it's too much work. I am, however, a big proponent of no-rust.
                  And believe me. My engine bay gets wet and dirty.
                    i am more along the lines of an ppg epoxy primer so as i can drop/throw a wrench at my engine bay and all it does is smile back......
                    So does it make me or you more of a ricer if i have a painted engine bay and 4 mufflers = quiet............or you with a fart can and not painted engine bay????
                    • ColinC Offline
                      ColinC Offline
                      Colin
                      i dont have a fart can. I actually dont have exhaust at all. Or headers. In three cars.
                      Or an engine. 😛
                        Or an engine. 😛
                        ha...no i wasnt aiming that at you... you didnt make the comment
                          i was just joking when i told colin it was rice..
                          and im sorry aps has all their exhuast with a 4inch tip. 🙂
                          • ColinC Offline
                            ColinC Offline
                            Colin
                            It's ok, I'm now the proud owner of a blitz Nur spec cannon with 3in catless single piece exhaust
                            • ihaveaidsI Offline
                              ihaveaidsI Offline
                              ihaveaids
                              Shaved and tucked engine bays are amazing. Don't know what you drive but here are some honda examples. Observe.
                              • dubbsyD Offline
                                dubbsyD Offline
                                [IM G]http://i172.photobucket.com/albums/w27/vtec112/eibach-126.jpg[/IMG]
                                [IM G]http://i172.photobucket.com/albums/w27/vtec112/eric032b.jpg[/IMG]
                                [IM G]http://i172.photobucket.com/albums/w27/vtec112/Ricky1.jpg[/IMG]
                                and not very good examples at that.
                                  They may be "clean" but they are far from shaved. look at 99 civics engine bay that is shaved and tucked. I spent way to much time on my engine bay.
                                    Those bays were tucked, not shaved, otherwise there wouldnt be holes anywheres....there's a K24 CRX on Honda-Tech, had everything tucked and everything shaved, complete down to the bare frame build...
                                      sweet mugen strut bar...doesnt king ricer have one :rolleyes:
                                      • ColinC Offline
                                        ColinC Offline
                                        Colin
                                        Back on topic: No shaving, Ford Gray bay, balcking alot of stuff: Crossmember,booster, slave cylider, vavle covers, itake manifold,
                                        Coming soon: red lines for the brake lines and hoses, steel braided fuel lines.
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          Rexwagon;172922 wrote:
                                          Ive seen a lot of ppl with theirs black so i would assume it should be all good. are you going to remove some of the holes in the bay to by welding them and grinding them smooth too? it gives it that real clean look. I like black because it looks cleaner after i wash it and it's hard to see oil leaks. Look at ZBrown's engine, its a showpiece
