  4. Painting an engine bay
23 Posts 15 Posters 980 Views
  • ColinC Offline
    ColinC Offline
    Colin
    RidinRails;172721 wrote:
    yes its rice
    thats funny from the guy with a coffee can coming off the back of his car 😛
    Again: performance oriented. ONLY WONDERING ABOUT THE HEAT REFLECTING/ABSORBING QUALITIES OF BLACK PAINT
    • ErikE Offline
      ErikE Offline
      Erik
      I can only think that heat issues would be light/sunlight affected. So an engine bay should really have no effect.
      Except for glowing exhaust manifolds.
      They call me, old man...
      • thurmanmermanT Offline
        thurmanmerman
        Ive seen guys paint it gray so they can tell if they are leaking any fluids easier. Im sure black spray paint won't have any affect on it at all. If it was like a high temp heat resistant paint then thats a different story.
        > Parker;299126 wrote:
        • black2gB Offline
          black2gB Offline
          black2g
          i've heard painting a block a certain color is bad for heat but the engine bay shouldn't matter.
          1995 Eagle Talon
          2000 Doge Neon
          1974 Porsche 914
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            Black is naturally a better absorber of radiant heat than other colors. So...I guess it will help you out some by absorbing some of the engine bay heat and conducting it through your body panels to then be convected into the ambient air.
              Ive seen a lot of ppl with theirs black so i would assume it should be all good. are you going to remove some of the holes in the bay to by welding them and grinding them smooth too? it gives it that real clean look.
              • ColinC Offline
                ColinC Offline
                Colin
                I'm not into "clean" it's too much work. I am, however, a big proponent of no-rust.
                And believe me. My engine bay gets wet and dirty.
                  i am more along the lines of an ppg epoxy primer so as i can drop/throw a wrench at my engine bay and all it does is smile back......
                  So does it make me or you more of a ricer if i have a painted engine bay and 4 mufflers = quiet............or you with a fart can and not painted engine bay????
                  • ColinC Offline
                    ColinC Offline
                    Colin
                    i dont have a fart can. I actually dont have exhaust at all. Or headers. In three cars.
                    Or an engine. 😛
                      Or an engine. 😛
                      ha...no i wasnt aiming that at you... you didnt make the comment
                        i was just joking when i told colin it was rice..
                        and im sorry aps has all their exhuast with a 4inch tip. 🙂
                        • ColinC Offline
                          ColinC Offline
                          Colin
                          It's ok, I'm now the proud owner of a blitz Nur spec cannon with 3in catless single piece exhaust
                          • ihaveaidsI Offline
                            ihaveaidsI Offline
                            ihaveaids
                            Shaved and tucked engine bays are amazing. Don't know what you drive but here are some honda examples. Observe.
                            • dubbsyD Offline
                              dubbsyD Offline
                              [IM G]http://i172.photobucket.com/albums/w27/vtec112/eibach-126.jpg[/IMG]
                              [IM G]http://i172.photobucket.com/albums/w27/vtec112/eric032b.jpg[/IMG]
                              [IM G]http://i172.photobucket.com/albums/w27/vtec112/Ricky1.jpg[/IMG]
                              and not very good examples at that.
                                They may be "clean" but they are far from shaved. look at 99 civics engine bay that is shaved and tucked. I spent way to much time on my engine bay.
                                  Those bays were tucked, not shaved, otherwise there wouldnt be holes anywheres....there's a K24 CRX on Honda-Tech, had everything tucked and everything shaved, complete down to the bare frame build...
                                    sweet mugen strut bar...doesnt king ricer have one :rolleyes:
                                    • ColinC Offline
                                      ColinC Offline
                                      Colin
                                      Back on topic: No shaving, Ford Gray bay, balcking alot of stuff: Crossmember,booster, slave cylider, vavle covers, itake manifold,
                                      Coming soon: red lines for the brake lines and hoses, steel braided fuel lines.
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        Rexwagon;172922 wrote:
                                        Ive seen a lot of ppl with theirs black so i would assume it should be all good. are you going to remove some of the holes in the bay to by welding them and grinding them smooth too? it gives it that real clean look. I like black because it looks cleaner after i wash it and it's hard to see oil leaks. Look at ZBrown's engine, its a showpiece
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          KA-T_240;174698 wrote:
                                          They may be "clean" but they are far from shaved. look at 99 civics engine bay that is shaved and tucked. I spent way to much time on my engine bay. And it was worth it, I'm jealous.
