  3. Wanted Ads
  4. WTB: Z32 MAF (n62) and SR20DET injectors x6
12 Posts 5 Posters 936 Views
  • ColinC Offline
    ColinC Offline
    Colin
    kinda what I figured, thought I'd try local first
      yup. this is for your subaru I assume? if so curious on your choice of nissan parts
        They both use side-feed injectors...not sure about the MAF tho.
        • ColinC Offline
          ColinC Offline
          Colin
          Raising redline means need more air. More air means more fuel. More air also means need more accurate reading on incoming air. Especially when you're shooting for 8K in a subaru
            but how will you adapt a nissan Mass air flow sensor to a subaru.
            • ColinC Offline
              ColinC Offline
              Colin
              they have this tool called a drill. then you use these things call bolts in combination with this other thing called a nut.
                washers?
                • ColinC Offline
                  ColinC Offline
                  Colin
                  Ah yes! the indominatable washers. Also silicone caulk.
                    why not just wire it to work? or are u wanting just the little thing that does the reading and adapting that into the subaru maf?
                    • ColinC Offline
                      ColinC Offline
                      Colin
                      I am just wiring it in. the drill is for my stock air tubing, the wiring is compatable with stock. Then it's one rom chip and the bigger injectors. done.
