  4. Bad day for a 455
Bad day for a 455
47 Posts 17 Posters 6.5k Views
  • ruthless351R Offline
    ruthless351
    Helped a friend today rip into his T/A this morning. This is what i found....the first pic is the harmonic balancer and chain. The second is the the timing gear. Look closely i know its not the best pic but you should be able to see the teeth. Enjoy!
      so how did that happen?... sucks
        Based on the look of the Harmonic balancer, I'd be suspect of the crankshaft's integrity. I know it's in a T/A, but is it an Old's 455 or an actual Pontiac engine?
        • BookemB Offline
          BookemB Offline
          Bookem
          If that's a double roller it would take quite a bit of destruction IE chain broke or more liekly what Wes said, too many r's on a weak crank.
          Legacy GT
          Gmc Suburban
          Hallorann: Fargostreet?
          Hallorann: No, I ain't.
            Its a Pontiac 455
              alittle JB weld and some duct tape and it will be fine!.... that has to suck
                ruthless351
                Ok......ripped the 455 out today after work and lookie what i found. This 455 has spun its last rpm. 🙂 Enjoy.
                All three are the crankshaft at different angles.
                  O SHIT! that just doesnt happen with out some serious issues.
                  • 81BNDT8 Offline
                    81BNDT8 Offline
                    81BNDT
                    Yeah....I cried inside a little inside when I saw my crankshaft all F'd up 😞 Sigh
                      Damn!! this is one time where I wish I wasn't right. That totally suck man.
                      • 81BNDT8 Offline
                        81BNDT8 Offline
                        81BNDT
                        Ya, it wouldnt be so bad if I weren't still paying for it....let alone the fact that it only had about 7,000 miles on the engine, but it's my project car and I have all the time in the world to make it the way I want it.
                        • 81BNDT8 Offline
                          81BNDT8 Offline
                          81BNDT
                          Suggestions for setup welcome.
                          • 94NDTA9 Offline
                            94NDTA9 Offline
                            LS7 swap.
                            IS your TA silver with a loud exhaust?
                              ruthless351
                              It is Black......but it loud as well.
                              • black2gB Offline
                                black2gB Offline
                                black2g
                                there is a t/a in west fargo with i 455 that just got put in a couple months ago. it's loud. might be the one your thinking of but i can't remember what color it was.
                                1995 Eagle Talon
                                2000 Doge Neon
                                1974 Porsche 914
                                  RB26 swap
                                  that will get some going...................
                                  • BookemB Offline
                                    BookemB Offline
                                    Bookem
                                    Just wondering if that's 7,000 on a rebuild or original miles? I'd lean towards a lighter 350 warmed over would be just fine, or 383 if you think you will miss the torque of the 455.
                                    Legacy GT
                                    Gmc Suburban
                                    • Gundar1G Offline
                                      Gundar1G Offline
                                      Gundar1
                                      zbrown;177191 wrote:
                                      RB26 swap
                                      2jz :icon_cheers:
                                      EVO
                                      • M Offline
                                        M Offline
                                        musthavemuzk
                                        ONLY option is going back to a pontiac 455.
                                        Monty
                                        14.59 at 94.85 still stock
                                        www.pbase.com/musthavemuzk
                                        • 94NDTA9 Offline
                                          94NDTA9 Offline
                                          ...with a blower...
