  4. in dash lcd
in dash lcd
16 Posts 7 Posters 841 Views
    I'm sure he does, since he refered to it as "the legal way"^^^
    • 3_Series3 Offline
      3_Series3 Offline
      3_Series
      But of course, I am blind.
      2002 Subaru Legacy
      1993 BMW 325i (sold)
        3_Series;175262 wrote:
        You do know it's illegal to be watching a movie while driving don't you?
        Who cares? Do you have any idea how many people do it anyway? If you get pulled over, just switch to the radio, no problem 😉
        • killer69penguinK Offline
          killer69penguin
          and what does it take to be hooked up the legal way thats kinda what i was askin might get a little help though at some time
          1993 3000GT VR4
            That depends on which unit you get. Some just need to have the e-brake wire grounded out, some need to see a certain sequence of the brake pedal and parking brake. There are ways around all of it.
              killer69penguin
              any chance you know about a jensen?
              1993 3000GT VR4
              • blindsp1B Offline
                blindsp1B Offline
                blindsp1
                im betting the jensen that u get at walmart..if so ill get u a sheet that tells you how exactly to do it..
                New Bike: 08 zx-6r FOR SALE
                05 Yukon
                  killer69penguin
                  haha yep it was acctually i returned that one though because i found a different one i liked on ebay and bought it but its still also a jensen
                  1993 3000GT VR4
                    Depending on the model of Jensen you have one of the follwing should work:
                    OPTION 1The parking brake bypass procedure is as follows:
                    1: Go into AM/FM mode
                    2: Hit "setup" on the remote control
                    3: Enter 543210 on the remote, listening for the beep for each number entered
                    4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
                    5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
                    6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another
                    Option 2:
                    Once you have everything hooked up pop in a dvd and when it starts playing do the following
                    Take the pink parking break wire and touch it to ground for 2 seconds, then remove it from ground for 2 seconds, then put it back on ground if at this time the screen starts showing the movie then keep it grounded, if not try to remove for 2 seconds again and then back to ground, you might have to ground/unground for 2 times or 3, ok now that you are grounded and the movie is showing use the remote and hit ( stop, stop, 1264) this should bring up a menu and one of the options in that menu will say something about the parking break bypass. if it is off turn it on if its on turn it off. I cant remember which one it is set at so which ever its on when you see that menu turn it to the opposite
                    wait for a few seconds and the menu should go away if not just hit tuner or tv or one of those buttons of the head unit
                    you should now be able to unground it and not even worry about that parking braek wire and everything is good to go
                      option 1 is for newer units, option 2 is for the older ones.
                        killer69penguin
                        thanks a ton that will definatly help!
                        1993 3000GT VR4
                          When you get the unit, the install manual will tell you what needs to be done, if Chuck's options dont work.
