  4. Coolant Leak
Coolant Leak
22 Posts 7 Posters 865 Views
    Buy a new belt and all the fixins while your in there (Idler pulley, tensioner etc.) If so equipped. Especially if the belt has seen coolant for any time.
    • ticklemedalyT Offline
      ticklemedaly
      if you havn't done a honda timing belt/water pump before, figure a good half days work if you have all the tools, more if not and have little experience doing any major repairs like this. for an expert, these are cake to do. I remember my first one I did on my 94 civic years ago, thought id never get it done, but i finished it in 8 hours (had class and lunch break in between at the tech) and never had a problem with it while I owned it. They are usually a pain the first hour or so because of all the belts you need to remove, once they are out of the way, along with the motor mount (support the engine with a jack) you should have a lot of room to get in their to do the belt and water pump. For ease of installation, make sure to paint your timing marks on your crank and cam pulleys and rotate them crank counter clockwise (im 98% sure that is the right way on that engine) till they all line up with their marks. Then tear into her!
      XBL G-tag: TickleMeDaly83
        It would be a wise buy to invest in a Haynes manual as well.
        • Turbo5OhT Offline
          Turbo5OhT Offline
          Turbo5Oh
          watch out for those pesky crank/balancer bolts!
            ticklemedaly
            Air Impacts are great for removing the honda crank pulley bolts.....and technically, they are not balancers fyi.
              I'd recommend a Chilton or something better, we sell Haynes at work and in my opinion they suck...
                I have had great luck with all the Haynes manuals I have had. Either way, get a manual of some sort.
                  Chilton FTMFL.
                  Haynes manuals are much better than the Chilton
                    ticklemedaly
                    OEM Honda Service manuals are made by Helms in which my opinion are the best for what I have found. Haynes and Chilton are the same in my opinion and expierience.
                    • DWeigsD Offline
                      DWeigsD Offline
                      DWeigs
                      I went out and got a Haynes manual, new water pump, and timing belt. So I should be good to go tomorrow when putting it in... Ill post it up on how it goes tomorrow!
                        So, how did it go?
                        • DWeigsD Offline
                          DWeigsD Offline
                          DWeigs
                          I went ahead and tore everything apart and it sucked... I couldnt get it.. So i hired a friend to finish it up for me for $35.00. Turned out real well lol!!
