  4. removing overspray..
14 Posts 10 Posters 698 Views
    yeah go to walmart and get one of the razors thats made for taking off paint. its like $2
      razor blades dont work so well on rubber and soft plastic trim. trying to keep most of this in as good as condition as possible.
        glass cleaner and a fine clay bar
          shoulda taped everything off then 🙂
            kevin rocks a mean claybar...
            • z31Z Offline
              z31Z Offline
              z31
              RidinRails;175586 wrote:
              shoulda taped everything off then 🙂 A must, or you have a mess....spend an hour taping and it 10 minuets cleaning up. Try same really fine steel wool. Keep the glass wet with glass cleaner if u use the razor blade on the windows .
              • ticklemedalyT Offline
                ticklemedaly
                rain-x removes paint on windows easily without scratching. as for the plastic and lights, you got me, never had any great luck in removing it from those.
                XBL G-tag: TickleMeDaly83
                  use a wire brush... that'l take anything off 😉
                    I bought a car that had some extemely shitty start on body work, there was bondo on the windows and all that. Its a long processes, but its getting better.
                    O and i know to tape stuff off, but this is what happens when you bring your car to a shady dealership that does a $400 paint job.
                    • GoodnbuzzdG Offline
                      GoodnbuzzdG Offline
                      Goodnbuzzd
                      I would say clay bar, or a good cleaner wax depending on how bad it is. my experience from working at a bodyshop is, tape tape tape anytime you do paint work. a clay bar and about two drops of dawn soap in about a gallon of cool water. if the paint is less than 8 months old, DO NOT use any wax or cleaner wax, paint has to cure for 6 to 8 months before you should wax it.:icon_salut:
                        ^rattle canned FTW!
                        I got most of it off, and did some custom painting to cover the rest LOL! Its my beater for now.
                        Next issues.
                        There is something on the back window, NO idea what but a razor blade or brake cleaner does not touch it. If you wipe it off it ruins the towl or what ever you are using, it is something on the glass not pits in it.
                        The kid must have sone to siant johns or something. I want to take the sticker off and NOT damage the defrost, being that somehow it got damged on my car and 240 fog up really fast even when warm out. I have tried glass cleaner and a rag, I can not even get the sticker to peal off at all just tryin a corner with a razor blade.
                        Thanks for the help
                        • thurmanmermanT Offline
                          thurmanmerman
                          You can get defrost fixer at the store.
                          > Parker;299126 wrote:
