  4. turbo or na
turbo or na
15 Posts 11 Posters 620 Views
  • beachbum_jonB Offline
    beachbum_jon
    alright so me and my friends were having a discussion on which is better on gas.
    the discussion consisted of topics such as turbocharged vehicles need bigger fuel injectors which obviously spray more fuel.
    but also at cruising speeds the turbo is a restriction in the exhaust system, but once you need power like going up hills or in the mountains, it is more easy to get power with the turbo pulling you through.
    does anyone have any takes on this. i know its hard to prove such a thing like this and the topic can be too sided and bascially it all comes down to your foot.
    thanks, jon
    -John Adams, 1735-1826-
      you are talking about gas mileage?
      if so, IIRC, a turbo vehicle should get better gasmileage while cruising on the highway. I am happy, i got 29mpg with the 240 driving 80 on way back from souix falls with no cruise control.
        i get 28 ish mpg in my probe when i'm not on it in town....
          ya, I dont get the best gas mileage in town. but its just soo much fun!
            beachbum_jon
            okay ka-t , i assume you have a ka24 in your 240, what does a na ka24 get for gas mileage on the highway?
              i actually have no personal expeince. never drove on the highway with my car. I have delivered them but dont fill the tank up. i got just under 27 with a auto, which in 240s when stock gets better gasmileage. but it was -20 so thats a big side affect right there
              I also think I would have better gas mileage with a bigger turbo, because it would take more rpm to spool. on the highway at 80mph, I am at 3200-3300rpm in 5th gear. which when I am full throttle at the rpm at am in the upper teens in boost. so if it hit a bump oops 10psi, lol
                2 words
                Volumetric Efficiency
                  Type much?
                  It all depends on your tune. It doesnt matter whether your turbo or N/A when you aren't in boost. most turbo people just have their cars tuned to be lean at low RPMS. Lean obviously means better gas mileage. i guess air swirling thought a turbo/Intercooler/ic piping might make a tiny bit of difference on gas mileage, but I highly doubt it.
                    beachbum_jon
                    i just mean factory tune...same motor same everything..like a na dsm from factory and turbo dsm from factory...everything is BONE STOCK. which will get better gas mileage average?
                    • mr.98gsxM Offline
                      mr.98gsxM Offline
                      mr.98gsx
                      The most I've ever gotten in my dsm is 26mpg that I know of. That was cruising to ndsu from mn. I can get as low as 16-18 mpg though sadly. 2.0L ftw lol!
                      • bader3245B Offline
                        bader3245B Offline
                        bader3245
                        The fact of the matter is both. There are so many variables that one could argue this for EVER. Flow of both air and fuel, restrictions wheter it be exhaust or intake. This is like comparing apples to oranges.
                        2008 Ford F-150 FX4
                        2006 Honda CRF250R
                        2006 Honda CBR1000RR
                          On my del sol, i consistently got about 32 mpg on it NA, when i turbod it, even before tuning i got 33 mpg, and that is usually what i got so i gained about 1 mpg on average.
                            aliengotpsi
                            I would say NA or gas mileage... I could never NOT boost...
                            Kevin Smith
                            Straightlinedetailing.com
                              thrash
                              bench racing is an ugly thing.
                              first off, to eliminate the chassis and driveline from the process, you need to look at the fuel consumption for a given engine output level with the engine on a stand.
                              Next, there's no magic involved -- making a certain amount of HP requires a certain amount of air, which also requires a certain amount of fuel. Of course, any engine makes power that you cannot measure at the crank.. this is power used to turn the alternator, or to warm the engine, or to pump the engines oil, etc.
                              It is my opinion that given two engines making identical peak power at the same RPM, with similar internal losses and accessory loads, the NA engine will use less fuel.
                              Of course, where are you going to find 2 identical engines that make the same amount of HP in both NA and turbo versions? If one of them is a 3 liter V6 vs a 2 liter I4 turbo, the internal differences will be intrinsically different due to different # of bearings, balance shafts, # of valves, etc.
                              I think as a practical matter, a smaller, lower displacement turbo engine can make similar peak power when its boosting, but be lighter and consume less fuel when its not boosting. The A4 2.0T gets better milages than the A4 3.2 V6.
                              Under boost i think an NA engine does better. Turbo combustion is less efficient than NA combustion i think, and most turbos run rich under boost. running rich == using more fuel than strictly necessary.
                              In around town driving, my A4 2.0T gets better mileage than my 2.8L NA V6 passat, which gets MUCH better mileage than my 3.5L I6 NA M5. The A4 is 200hp, the VW is 190hp, and the M5 is ~250hp. The A4 is actually the heaviest of the vehicles and has the most drivetrain losses. It's also got the most efficient engine design with the most modern technology.
                              • black2gB Offline
                                black2gB Offline
                                black2g
                                For the factory specs on a 92 talon it says the na gets better gas millage.
                                http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1992&make=Eagle&model=Talon&trimid=-1
                                I think the exact same engine was used on both na and turboed versions of this car for that year.
                                http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1995&make=Eagle&model=Talon&trimid=-1
                                the 2g was very close for gas millage but differant engines were used.
                                http://autos.msn.com/research/vip/Spec_Glance.aspx?year=2007&make=Chevrolet&model=Cobalt&trimid=-1
                                the supercharged colbalt get worse milage than the na colbalt.
                                1995 Eagle Talon
                                2000 Doge Neon
                                1974 Porsche 914
