  4. Got some sweet toys for the 240 today
18 Posts 8 Posters 641 Views
    First, I finally got a Pignose lip for my car, neds some paint. But I don't care. It will be painted before I mount it on.
    Second, A set of brand new 26x10x15C MT ET DRAG Slicks. I am new to this sort of stuff. But go to learn sometime. Got them for $250 for both.
    Next to my 255/40/17
    To you slick experts. I plan on putting these on a 15x8 weld draglite. Do I need tubes for these. I purchased these from a guy down in the cities and he said you really dont need them, but the jegs catalog says you should have them. He seems to know what he was doing when there was 1 500whp civic and full drag(no motor yet) civic that was just nuts right next to it.
      faber finally got slicks y0!!!! d00d you need to brake boost that shiz @ 10mph with them slicks! lol
        lol, not going to be on until next spring. I dont think my current drive shaft will be loving life... I also want to try and get way lower in the 12s on street tires this year. hopefully at the last track day with stock suspension in the back and some 275s
          ooo about time man. do we really have to wait till next year to see that thing get unleashed. either way im diggin the lip.
            ya itll be painted and on next weekend. I can not afford, Drag lites, a custom drive shaft and drive shaft loop at the moment. Over the winter I should aquire all this. If someone want to sponser me:icon_thumright: then It can be arranged for the last street legal day.
            I also am going to try and swap to a stand-a-lone or something better then my current tuning setup. I am thinking its going to be like a chipped ecu, but live edit and i can adjust it with my laptop when I want.
              you would need tubes in those for sure. some people dont run them, but the general consensus is that its a good idea.
              AND, if you didnt know it already, heres a nice little suprise!
              http://home.aanet.com.au/nistune/
              Gary
                You don't need tubes in your slicks. You will just have to air them up before you go to the track every time.
                Drive shaft loops are pretty cheap too and you can probably avoid having one for the last street legal day if you show up with street tires first. 😉
                  Just go get it tuned and leave it alone...
                    Gary
                    On that site they talk about calumsult. That is what I am getting. They are both about the same thing, but that calum is US, and would be cheaper. I can send him my chips out of my ecu now and hell upload them as a base map for no charge. Its like right around the $300 range, and I can sell my 2 enthalpy ecu's and afc neo for way more then that.
                    The main reason I want the calum is becuase i have a sohc to dohc swap in my car which makes it so you cant use the consultport anymore, he has it available via the ecu:icon_albino:
                    Ya, I dont think ill put tubes in, unless i start having some major issues. Putting air in them is easy. 8-10psi is around what I was thinking for tire pressure, not sure.
                    anyone know where to find some cheap weld draglites?
                      What you said makes no sense. especially when you quoted something about tires.
                        Cheap and weld wheels dont usually go together. If you wanted something quick and cheap so you could at least race this year:
                        http://www.circleracing.com/
                          lol. ok cheap drag rims. or the cheapest place to buy welds? dirt track rims are heavy as hell. I want to spend my $$$ once and do it right the first time.
                            It's a $120 purchase. Consider it a disposable expense for the end of the year.
                              What are you looking for sizes?
                              Check tcstangs or corral.net. TCS might have something local, and corral has a lot of stuff
                                15x8 5.5 inch backspacing bolt pattern is 4x114.3(aka 4x4.5). in weld draglites or something similar.
                                are fox body mustangs 4x4.5?
                                  They are a 4x108 for the fox bodies
                                    damn thats out.
                                    • itRfanI Offline
                                      itRfanI Offline
                                      itRfan
                                      Lip looks good faber, hope to see her on slicks next year before i leave?
                                      -weshole
