Monte Carlo
um, i would MUCH rather have the Z, those thing are built like tanks, and corner, brake, and look awesome. All it needs is a LS1/T-56 swap to be perfect.
BTW, what "turbo kit" did you get? Z7? cartuning? also what "piggyback system" is this, cause far as i know, that is pretty much the worst way to tune a car. Now if your using DHP, then its just fine, but not considered a piggyback. Also i wouldnt go over 7-8psi on that thing, unless you have alot more goodies than i think you do.
L36 on 8psi is good for about 230whp just for you guys and gals to know, wont be much of a problem for most of you, attribute its slowness to shitty tires and FWD. probably run around a 15 flat at the track, maybe a 14.8 if hes really really lucky.
Gary -
Johnny Carlo;185101 wrote:
Wow, I bet you waited until you were 21 also.Except that im still not 21............
And also, FMUs are a worse way to tune a car, but yes, piggyback systems aren't much better.
inspector01;185142 wrote:
Except that im still not 21............And also, FMUs are a worse way to tune a car, but yes, piggyback systems aren't much better.
Well my piggyback system is good. I dont care what you think. It controls something called knock, timing, and fuel. Also can set up a stutter box with it. I dont know what that is tho.
Johnny Carlo;185148 wrote:
Well my piggyback system is good. I dont care what you think. It controls something called knock, timing, and fuel. Also can set up a stutter box with it. I dont know what that is tho.:icon_queen: ok princess
Grr;185156 wrote:
soooo, you gonna answer any of my questions?
Garyit burns an image into the ecu each time i re program.
well thats how they all work. is it a Predator, DHP powertuner, EFILive, or HP Tuners software? Hope your buddy knows what hes doing cause you can fuck up alot of shit doing that. aaaannd, what turbo/ turbo kit is it. you bought it, you should know.
Gary
BTW, thats not a piggyback system, its a ROM editor. -
GaryT67
Grr;185163 wrote:
where did you get it from.online store...
I will once I smoke all those racers out there. I better not give out that information beforehand.
Grr;185174 wrote:
ooooook then. still, if you dont have supporting upgrades, its not going to be very fast. 3" exhaust, intercooler, injectors, fuel pump would be a good idea. im pretty sure i know what you bought. still about 250whp with the t67.
GaryMaybe you can help me one day and give me more advice.
