missing cam
Ford engine bays are a complete nightmare. Those pics make me squeamish. I had a 85 Bronco II with the V6 and that thing sucked something fierce.
Here's the engine bay of the 1991 BMW M5
3.6 liters, 24 valves, 6 throttle butterflies, 310hp, ~270ft/lbs, 7000 rpm, DOHC, shim-over-bucket.
thrash;185977 wrote:
Ford engine bays are a complete nightmare.You can say that again.
Hmm, I haven't had a problem with Ford engine bays. The Expedition with the 5.4 is a little on the tight side, as is the Modular SN95 'Stangs, but other than that they really aren't that bad. I have a 92 Explorer with the 4.0 V6 (basically the same as the truck you had) and there is LOTS of room in there.
The issue is about the rats nest of wires and hoses. Yeah, there's plenty of room in the mustang -- and its all filled with shit.
Look how clean the layout of the M5 engine bay is. Everything is routed logically and cleanly. It's easy to tell what everything is and what it connects to.
MisterCMK;185996 wrote:
Hmm, I haven't had a problem with Ford engine bays. The Expedition with the 5.4 is a little on the tight side, as is the Modular SN95 'Stangs, but other than that they really aren't that bad. I have a 92 Explorer with the 4.0 V6 (basically the same as the truck you had) and there is LOTS of room in there.Modular 4.6's and 5.4's are some of the biggest (dimensionally) engines Ford has ever made. They are way too big and way too underpowered.
MisterCMK;186017 wrote:
I agree with that. Never said that they weren't.Yeah I'm not sure why I hit the quote button on you there, meant to just say what I said and nothing else.
I have a 92 Explorer with the 4.0 V6 (basically the same as the truck you had) and there is LOTS of room in there.Lots of room my ass..
not when you need to change plugs from the god damn wheel well on the passenger side....
I can actually SEE where the plug wires end on the Tahoe...
97lt1;186143 wrote:
You guys have never worked on a LT1 f-body. If you can work on one if these you can work on anything.I think you'd say the same thing about a Supercoupe.
I remember a buddy showing me pictures of the only real easy way to change spark plugs... the heads were on the work bench.
Parker;186095 wrote:
Fords new emblem
lol i changed the background on my managers computer to this^^ he drives a mustang also
Its about damn time you finished it....remember when i spit in your engine?
