  4. Disconnecting the "rev limiter"
27 Posts 14 Posters 934 Views
    ^^ They don't know what they're talking about. Get rid of it. You don't need it.
    Once you get it taken care of, set up a video camera and stomp it down in neutral.
      ^^^ yeah! and spray ether in the intake at the same time! ooo the horsepowa!
        n00b
          No, spray nitrous into the exhaust. and then shoot the bottle from a rocket riding away.
            why the hell would you want to do this anyways?
            • z31Z Offline
              z31Z Offline
              z31
              JN210;186036 wrote:
              Would it be a good idea for an automatic? If i did disconnect the governor would it still shift or would the RPM's keep getting higher? I want to disconnect my governor but I'm afraid my car wouldn't shift "seeing as how it's the "rev limiter" " so i guess my main question is "Would my car still shift after disconnecting the rev limiter"?
              Thanks The answer to your question is yes, the transmission will work the same, and No I wont tell you how to do it.
              Like every one else said, why would you want to raise the red line? :icon_scratch:
              • ColinC Offline
                ColinC Offline
                Colin
                In many cars that I've come across have rev limiter set to maximize factory settings.
                Using my swap as an example:
                makes 240 hp and trq on an N/A 6. redlines @ 6200. Only available in an automatic, and uses 2 indiviual intake manifolds connected by an Iris valve that can open for "power" mode. Has serious breathing and exhaust issues.
                If i freeze the iris valve open, remove the 6 miles of intake and put on a high flow filter, then run good exhaust, the engine can make power up to 7500 RPM. The reason they limited the reving was because of a shitty exhaust/clearing stroke on the cams plus the poorly flowing exhaust found on all subarus.
                I'm sure other cars have similar setups...
                do the research, what are the limitations and why? check, check, data log, then do...
                  yeah, not a cool thing to do. with your stock cams, your car stops making ANY power above 5600. Jason had big ass cams in his with the N/A auto, and it still started falling off over 6500. Waste of time, and i wont tell you how to do it either.
                  Gary
                  • z31Z Offline
                    z31Z Offline
                    z31
                    Here is the stock dyno
                    http://z31.com/faqu/k&n.cone.filter.dyno.stock.na.jpg
                    Disabling the fuel cut (rev limiter) is going to what?
                    • JN210J Offline
                      JN210J Offline
                      JN210
                      Well, I just wanted to see if it was a good idea or not, guess it's not so great. I read off this one forum where this guy took his out, And he showed how, I wasn't really to keen on the idea so i wanted to know what you guys thought.
                      *1989 Nissan 300ZX Z31 *
                      > DelSlow;262050 wrote:
                      > I like the new JN210
                        why would you WANT to do it though, what was your main reasoning for doing it?
                          You can do it; but, you won't make power up there, and things are probably going to brake.
                          • ZeroZ Offline
                            ZeroZ Offline
                            Zero
                            when they say "brake" they mean break, and what they are talking about is probably the torque converter. they can explode at high rpms, at least from what i've heard.
                            You should do other mods first, like different intake manifold, full exhaust, make the stock setup breath better, you'd notice more gains anyway.
                            Chocolate Rain ;)
                            MPI conquest
                            • JN210J Offline
                              JN210J Offline
                              JN210
                              Well my main reasoning for doing it before was to see if i were to get a "power gain" well now i see that the idiot who disconnected his was wrong, i think i will leave it alone. I am however going to build up my VG and turn it into a HP beast, im going to turbo it and while the engine is out of the car im getting a 5-speed trans. (if i can find one cheap) and I'm also going to build up my engine while i have it sitting on the engine rack.
                                my suggestion: Take out the engine/trans, and give it to jason with a pile of cash, we'll get it in line
                                Gary
                                • StangerBanger96S Offline
                                  StangerBanger96
                                  Umm, the torque converter would be the least of his worries if he removed the limiter and felt he could safely hit higher than stock RPM. Valves could start floating, Piston to Valve contact could occur, anything in the heads could start breaking due to subjection to stresses it wasn't intended to see. Anything involving rotating masses would be subject to failure if he wasn't running an engine built to handle the higher RPMs.
                                    if you want a real z car, just buy a 350, done...
                                      StangerBanger96
                                      Overrated waste of $$$
                                      Oh and before you even say it, Stock GT vs Stock 350 is a drivers race, and there is a nice price difference between the two.
                                      • JN210J Offline
                                        JN210J Offline
                                        JN210
                                        So i should let Jason build my Z engine?....and how much would he want to do that for me?
                                          send him a pm, should have his at sabin soon, youll have to check it out.
                                          Gary
