  4. Rebuild kit?
Rebuild kit?
28 Posts 9 Posters 1.3k Views
                        Seeing as how noone has even bothered to answer your question, I will give it a shot. I've actually had good luck talking to the local machinist about what I wanted to have done. He will easily be able to get your parts. They can be a wealth of knowledge as well. Also, by having them get the parts you need.... he may also cut you a package deal on parts and machine work. It's also in your best interest to get in good with a machinist. That also may be the difference between getting the best work he can do and also making sure your shit doesn't get pushed aside for someone elses. And believe me, IT DOES HAPPEN!
                        I hope this helps out somewhat.
                        • CRX_CivicC Offline
                          CRX_CivicC Offline
                          CRX_Civic
                          Its for my engines class at MSCTC. i need to build, rebuild a engine. so i thought it would be a good idea to to the engine outta my civic. 206,xxx miles, smokes a little, leaks a little more, and it will be parkd for winter anyway. i would like to do a boost build but i need to start it within 2 weeks, so that leaves me know time to save some $. so yea, any ideas on cheap/good parts i can get in 2 weks
                            Roughly how much money do u have to spend?
                            • BlackEJ8B Offline
                              BlackEJ8B Offline
                              BlackEJ8
                              ^yeah building for boost can get pretty spendy...what do you plan on replacing?
                              off topic but Im pretty sure I saw you/your car while I was on a campus visit at msctc.
                              Honda Civic Si - Daily
                                o i live for building d series for boost. how much power you wanna make?
                                  CRX_CivicC Offline
                                  CRX_Civic
                                  idk how much power, enough to make pontiacs look stupid but be able to withstand driving everyday. i could have mabey 1000$ by the time i need it........were did u see my car, cuz if it was when i had it on the hoist it was pretty nasty...
                                    seals are expensive, no way around that. But rings/bearings are cheap and someones gotta have em in town.
                                      ebay, get a full set of ACL rod, main, and thrust bearings for like 60-80 shipped. rings will come with some vitaras if he goes that route, they also sell a kit that come with pistons, head gasket, timing belt and some other crap too. get some TT rods, and a bottom end gasket kit for like 170 dollars from honda. these are just the prices off the top of my head, my prices are inaccurate cause i always get ill deals
                                      hone and notch that bitch and your ready to go.
                                        Yea, you can build a D-series for boost for around $500 if you search for a bit, easily $700-800. Look around, ACL bearings off ebay, vitara pistons, eagle or TT rods, misc seals and gaskets, you are looking at $700 and a set up for 400 whp.
                                          Take spanish-rice and inspectors advice...they know how to build the d's for boost...if I ever went that route these are the guys i'd go to
