  4. Boost Controller
Boost Controller
41 Posts 16 Posters 2.4k Views
  • D S ohMD Offline
    D S ohMD Offline
    D S ohM
    Go manual. Like Faber said, you'll just keep upping the boost...and it's usually all downhill from there.
    I wanna go fast!
    • JN210J Offline
      JN210J Offline
      JN210
      Alright, manual it is then.
      Thanks
      *1989 Nissan 300ZX Z31 *
      > DelSlow;262050 wrote:
      > I like the new JN210
        Sell you mine for 25 bucks. its a manual one, the same style as they sell at SLS.
          There's nothing better than pushing a few buttons to switch between boost settings. Manual ones are a pain in the ass to get set properly and you never really know how much you're actually turning it up. AVCR isn't that hard to put in either, as long as you have a little knowledge on wiring and vaccum lines.
            well being that hes putting this on a NA motor, and using a pussy T3 turbo the most boost he will be able to run is about 6-7psi, so its not like hes gonna be adjusting it all the time. BTW, if you have any intelligence, dont put ANY type of boost controler on it until you upgrade alot of other stuff. Stock boost with the T3 is 4.5 psi, leave it there or youll just blow it up. Thats a whopping 220hp BTW, and the T3 will max out around 300hp, at the crank, not the wheels.
            On second note, your NA auto trans is gonna be shot in a couple weeks anyway, the turbo auto uses a different stall converter with a higher stall and no lockup, plus bigger clutch packs and valving. We had a hard time getting NA autos to hold on jasons car when it was NA, with cams and headers with 200hp, good luck
            Gary
            • JN210J Offline
              JN210J Offline
              JN210
              uh oh, So now I need to find a WHOLE tranny? well, I guess I could turn it to manual....think I could land one for 200?
              • JN607J Offline
                JN607J Offline
                JN607
                Thanks for sharing that info with us AFTER we bought all the shit......Should have spoken sooner Gary.
                2004 Scion xA
                Airman First Class Nelson
                  Cause he is responsible for making sure that you know everything you need to. God forbid you should have to do your own research.
                  • JN210J Offline
                    JN210J Offline
                    JN210
                    lol, thanks. Well....Josh....i got a looooooong road ahead lol. This will be good time to spend with the family eh? this will go over well with our dad...."hey dad, guess what?....I bought a turbo and now I need a manual Tranny!!"
                    This will be a good opportunity to swap to a manual as well....
                      well its worth a try, it will hold for awhile anyway, just take it easy on the shifts. i wouldnt worry about it until it starts slipping. BTW, its a pretty low mile unit im guessing
                      Gary
                      • z31Z Offline
                        z31Z Offline
                        z31
                        His first mod needs to be an auto to manual swap and I also said in a post the non turbo trans does not Hold much more power than the non turbo makes :icon_brilsmurf:
                        Post # 32 http://www.fargostreet.com/forums/showthread.php?t=10986&page=4 :icon_scratch:
                          ^O snap!
                          And research pwnz! Read on the z31 forum, dont post questions. spend a month reading. before you even pull your car aprat for turbo parts, make it a 5-speed.
                            Id stay away from an EBC..... or else you will learn your lesson
                            too easy to change, "oh whats 2 more psi".... boom
                            i had a Blitz SBC IDII, top of the line, now just a manual..under the hood, actually Matts
                              buy the ebc and sell it to me:D
                              • z31Z Offline
                                z31Z Offline
                                z31
                                I use a two stage manual boost controller :icon_cheers:
                                http://boostvalve.com/nissan_2.html :icon_bigsmurf:
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  Well, hell.....now I'm actually considering an engine swap.....again.....
                                    d16z6?
                                    • JN210J Offline
                                      JN210J Offline
                                      JN210
                                      lol^ in my Z31? I think I'll pass....I wouldnt even bother with a honda engine in a nissan lol. I think I might just do what need be done and do an engine swap with a 200SX (sentra) and throw in a SR20DET...
                                        wow, your an idiot. the wind blows and you change your mind, start to think about things, or sell that car so you dont fuck it up. Do you think your just gonna bolt on a couple parts and have a reliable 400hp car or something? Most of us ( me included, twice now)have shit tore apart for 6 months to a year to do major surgery like adding a turbo. Get a fuckin clue or quit posting stupid ass threads. Your pissing me off, nice car like that and you dont have a fuckin clue.
                                        /rant
                                        Gary
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          Well, I think that about sums it up
                                          :machinegun: :deadhorse:
