  4. 14b?
14b?
8 Posts 4 Posters 966 Views
    I am wanting to know what would all be involved in swapping the IHI-whatever Snowmobile turbo off my probe and putting on somehting cheap Like a 14b, 13g or big 16g. I think I could probably find someone around here that has one laying around. I know I'de nee da new manifold, and i think ide probably need new piping although I am doing a bigger FMIC hopefully this winter anyways. DOes anyone know where I could find or get a 1g manifold tweaked or something to fit the new turbo? nay help would be wonderful.
      I'd talk w/ Matt Faul (Fallguy), he might have some parts laying around that he wants to part with.
      BTW, how did the relay pack that I wired for you work out? Must have worked, I didn't get any phone calls bitching me out. LOL
      • JOHNDEEREJ Offline
        JOHNDEEREJ Offline
        JOHNDEERE
        what do you want to pay for a 13g or 14b heck a big evo 16g..
        Kevin
        sls
          Looking around seems all of em are going for about 100 bucks on the internet used. Ill stop in and talk to you more about it next week. I'm planning on buying MBC, air filter and some other shit from you guys, maybe we can work out something.
          • W Offline
            W Offline
            Wizard
            I actually had attempted this a while back on a 88 GT. The main problems were the orientation of the turbos are different (14b faces passenger side), the exhaust manifolds (3-bolt for probe/Mx), and of course the oil and coolant lines are all different. Most 13g/14b's in good shape go for around $100-250. But considering the massive amounts of work that need to be done to fit it, It would be more cost effective to buy a new upgraded turbo for it.
            The old MX-6 5-spd we had was purchased for $700. It had 282,000 on the clock on was very nice except for all maintainence items like brakes, broken corner lens (shocker), needed tires and the correct radiator. After about $600 of radiator, brakes, plugs, wires, fuel filter, etc. We installed a 1g BOV, 3" turbo back exhaust with cat, boost gauge, and open element air filter. Advanced the timing a few degrees and first pass at the track was a 14.6 at 98mph. Not bad for a tiny turbo at only 8-psi and a nasty slipping original clutch. I figured with a good ACT clutch, upping the boost to around 14-16psi. max, and some good driving, an easy 13-sec 1/4 would have been in reach.
            So I wouldn't consider the 14b swap unless you plan on really getting serious with the car in which such mods would justify it. Ie, a much bigger turbo in the future, etc.
            Wiz
            1992 GVR4 598/1000 Nile Black
            1992 Tsi AWD
            1982 Datsun KC 4x4
            1990 Laser 2.0 AT NT
            1994 ES 2.0L NT 5-spd
              Thanks for your help. We just got done ripping off my manifold, and it was being held on by 2 bolts when there aresupposed to be 6. We det in on a straight piece ov metal and came to the conclusion that its warped horribly. I am looking to buy a new manifold, or buy a DSM manifold that will make this 14b project much easier, since I need a new manifold anyways(or waste $$$ getting it planed). I have a 14b that will be given to me to used for as long as I want, free of cost. I really can't pass it up, considering I'm running out of money. What FMU did you find you could use. I'm having trouble finding one.Everyone on Probetalk and cardomain with 1st gen gts uses an adams fuel chip, but i dont just want to chip, I want to do it right.
              • W Offline
                W Offline
                Wizard
                We didn't have any fuel control. But we were planning on swapping to a late-model Mazda MAS and running an AFC. Or just use the current MAS and setup for early Miata on the AFC.
                Wiz
                1992 Tsi AWD
                1982 Datsun KC 4x4
                  i have a 2g mani if you need one
