  3. Wanted Ads
  4. 1g mani.
1g mani.
23 Posts 8 Posters 1.8k Views
  • DrifterExtremeD
    DrifterExtremeD
    you can weld them with the correct rod.
    • bubbaB
      bubbaB
      KA-T_240;194214 wrote:
      if the manifolds are cracked, and cast. you can't weld them. SLS might have one, I know he has lots of DSM parts. if not just buy a header of ebay! lol.
      You can weld cast iron...I believe u need to use nickel rod and really know what you're doing...my grandpa had told me how to do it one time, as he used to weld pretty much anything, but I forgot...
      • DrifterExtremeD
        DrifterExtremeD
        are you tig welding or stick. if tig i think some ni-rod 99 filler should work.
        preheat to a good temp, then weld up crack, then stick it in a bunch of sand to allow it to cool very slowly.
        • bubbaB
          bubbaB
          I was talking about arc...
          • DrifterExtremeD
            DrifterExtremeD
            they also make it in a stick rod.
            • beachbum_jonB
              beachbum_jonB
              beachbum_jon
              thought the key to cast was fast and cool, rather than slow and hot. but maybe i am mistaken, my grandpa also told me how to do it along time ago. he use to be a certified welder and as been the head welder in many buildings that have been erected during the 1950's.
              -John Adams, 1735-1826-
              • DrifterExtremeD
                DrifterExtremeD
                well if you do not pre heat the cast and then also try and cool it fast, you can acually hear the peice crack, sounds like little poping noise.
                • beachbum_jonB
                  beachbum_jonB
                  beachbum_jon
                  okay then i was mistaken, i knew it was one or the other
                  • iluvracingI
                    iluvracingI
                    iluvracing
                    does sls have headers or just the stock manifolds because I looked on ebay and all I can find is stock... I would like to get aftermarket headers at a decent price....
                    96 sunfire se pos!
                    2002 v-star 1100-For Sale. (NEED GONE!)
                    91 Eagle Talon (hopefully running for auto-x)
                    97 F 150
                    • wesholeW
                      wesholeW
                      You can weld it with nickel rod. But, it will not last and start to crack right from where the weld ends. Been there and done that.
                      • iluvracingI
                        iluvracingI
                        iluvracing
                        thanks man. I got a friend that can weld like theres no tomorrow and might have him weld it up for the time being but wanna know if I can get a nt header somewhere for a decent price... don't wanna spend alot of money!!!!
                        96 sunfire se pos!
                        97 F 150
                        • DrifterExtremeD
                          DrifterExtremeD
                          if you drill small holes right were the crack starts and stops it should never crack again if welded properly. you just need to make sure you stoped the crack from being able to start up again.
                          • K
                            K
                            • SPANISH-RICES
                              SPANISH-RICES
                              • K
                                K
                                • bubbaB
                                  bubbaB
                                  • iluvracingI
                                    iluvracingI
                                    iluvracing
                                    Thanks for the advice
                                    96 sunfire se pos!
                                    97 F 150
