  4. Ready for engine paint
15 Posts 4 Posters 1.3k Views
    Im closer to geting it painted up now, everything is off and ready to come out, need to finish making my accessory bracket and go over the oil pan with the TIG to seal a couple pinholes up, then blast and paint. Ill post updates of the work as it progresses.
    Gary
    • z31Z Offline
      z31Z Offline
      z31
      A couple of cans of krylon should do the trick. :icon_scratch:
        Holy shit, how about an update! Motor is all painted and ready to go back in. Thanks to Jason for the work, it looks fabulous and i am very happy with it.
        Also the frame is all cleaned up, and the A/C box is in. All the wiring and dashboard is in.
        For the firewall i welded up a couple holes and then coated it 3/8" with a product called "Firewall" from second skin audio, which is a liquid, ceramic based sound and heat barrier. On top of this i applied some closed cell foam from same and also put foam on the heater box, all ducting and the inside of the dashboard. Dash is all installed, along with controls and stereo in and working, minus the sub.
        Waiting on the steering, which i plan on ordering end of next week, then the motor goes in and some re-doing of the wiring from computer into cab. Flange for turbo, add wastegate, and make downpipe and it will be driveable again.
        And there will also be a security system, and i have 2 absolutely hidden kill switches wired in, along with a GPS tracking device that is impossible to find, so if anybody is planning on fucking with it like they did to zacs car, fuck off.
        http://s214.photobucket.com/albums/cc192/Grrh77/
        Updated pics are in the link! Comment if necessary
        Gary
          Man I have to say Jason (z31) does good work....
          Glad every time i look at my engine it got into his hands
          • z31Z Offline
            z31Z Offline
            z31
            Zack, we need install a painted automatic trans in the 7. :icon_cheers:
              Since its been FOREVER, an update~!
              Heres how it sits tonight. Out with the old rear, its going to a new home.
              Engine and trans are re-assembled and the stall is in there. Most of the wiring is done and secured, just need to finish looming the intake wiring once its in the car and hooked up. Also the A/C box is all put together again. The 9" is in the mail and should be here monday, ill post pics of that when it arrives as well.
              The first 6 pics are new.
              http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
              Gary
                a painted tranny makes up for a weaksauce 4.8?:icon_scratch:
                • z31Z Offline
                  z31Z Offline
                  z31
                  ^^^6.0L 4l80
                  Weak :icon_bigsmurf:
                    wow.... where are you at.....
                      i was talking about zack... but now realize that was a very very old post... but still...
                        we can still be friends??
                          well..... i supose...
                            Today i got the motor set in the chassis again. Man does it look sweet, I also put the manifolds on to check out clearances for the downpipe and placement of O2 bungs. Hopefully the 9" will get here tomorrow, and i plan on getting the harness all wired in this week.
                            • z31Z Offline
                              z31Z Offline
                              z31
                              There is no "I" in TEAM. :icon_bigsmurf:
                                fuck that, i lifted it in with one arm, alone
