  4. Plane on a conveyor belt
298 Posts 57 Posters 19.2k Views
  • JN210J
    JN210J
    JN210
    I think someone should actually try this at home....with an RC gas plane and somekind of belt....just a thought.
    *1989 Nissan 300ZX Z31 *
    DelSlow;262050 wrote:
    I like the new JN210
    • SmitEvoS
      SmitEvoS
      thrash;199285 wrote:
      that's probably a bit harsh. A teachers job is to indoctrinate students with government propoganda, not solve riddles 🙂
      Lol...lay off the crack man.
      • HandoEXH
        HandoEXH
        tjamz and thrash have hereby gone completely crazy.
          thrash;199282 wrote:
          I beleive these statements are both false. You are in effect asserting that fluid dynamics does not exist.
          Have you ever been to the lake before? Stand on the dock, hold on to a boat via a peice of rope. Are you saying the rope tension never changes because of waves or currents in the water? Are you saying that no matter what the water is doing, the tension on that rope (and via extension, the force you apply) never changes? I don't think you are... 🙂
          An external force (you, attached to the land), trying to hold an object still in a moving fluid (air and water are both fluids) will need to vary your supplying force to counteract changes in the force the fluid is applying to the object.
          Ok...I may be off in my assessment here, I was merely going off what was presented to me on phys.org and some pilot forum I was on. The conclusion, on both, was that once the airboat/seaplane were moving, the waters direction & speed had a very minimal affect on whether they could take off (or travel in opposite directions in the case of the airboat which is not designed for flying) or not.
          I see. In that case, next time someone is doing a 1000hp dyno run, instead of using multiple ratchet straps, why don't you just hold onto the car yourself? 🙂
          This is a bit different though, in this case the car is pushing the rollers, not vice-versa, so therefore the car is generating the forward motion. See my analogy of a toy car on a belt sander earlier in this thread for reasons why I think I can hold a car from crushing me on a conveyor belt (assuming the car is stationary and in neutral at the start of the test and I don't have to overcome momentum as well)**
          If you were to replace the "you" in that picture with a spring, the spring will slowly compress as the speed increases, because we are talking about an imperfect system with non-zero mechanical losses.
          This is incorrect. If for no other reason than there is no ground-launched lift-effect aircraft with a takeoff speed of 300mph. You won't see a plane making 300mph on land during a takeoff run 🙂
          I said belt speed, not plane speed. The plane (if its a 747 for example) will take off when it achieves 180mph relative to the ground.
          In any case, suppose the landing gear is a square block. The plane will certainly not take off.
          If the square block is extremely slippery, it certainly could.
          Suppose that the landing gear is a frictionless rolling assembly. The plane will definitely take off.
          Assume it has its normal friction and it will as well
          Reality is somewhere inbetween. That's why you can't make this an absolute statement.
          **I'm pretty sure that just about everyone would agree that the scenario at hand assumes that the aircraft in this riddle is in normal operating condition. Throwing oddball scenarios out there certainly make it possible for it not to take off. Why not say something like "well, what if the plane has 3 engines pushing it forward and 9 engines pushing it backwards and the 3 forward engines only produce 10000 lbs of thrust each and the 9 backwards engines produce 100000000000 lbs of thrust each...can the plane take off?" Of course not. **
          I'm not sure what physical property of aircraft you are referring to such that you can claim that no matter what, given enough time and distance, the plane will accelerate enough to take off.
          So long as the aircraft can generate enough thrust, in enough space, with enough fuel, to overcome the momentum generated by the plane moving backwards at 300mph, the plane will take off. Every time.
          Again...clarified.
          As for the original question, the plane will always take off under normal conditions/parameters of the question. There is absolutely nothing that the BELT itself can do to prevent this if it follows rules of the question. The only thing that can prevent the plane from taking off is the plane itself.
            glad you asked...
            http://www.youtube.com/watch?v=-EopVDgSPAk
              JN210;199280 wrote:
              woah...easy, I just asked him if it would take off and he simply gave me an answer.
              And I think he is retarded. Have him read the whole thread, and seriously think about what he said. If he still thinks that way, he should be fired.
                lol, I think only he and I actually read each others threads.
                • HandoEXH
                  HandoEXH
                  Nope, Brian reads them and then gives me cliffs:)
                    In that case, brian is crazier than both thrash and I.
                      I didn't get to 7059 posts on this forum by sitting around and not responding...
                      • JN210J
                        JN210J
                        JN210
                        ^no kiddin? I think I will see if my teacher has anything more to say on this subject, I will show him what you all think and have him read up a bit on this, then I will see what he has to say.
                        • bubbaB
                          bubbaB
                          Didnt we agree at Bdubs that every post over a certain length needs to have cliff notes...some of us dont have the time or attention span to read some of this, lol....
                          • JN210J
                            JN210J
                            JN210
                            what would the cliff note be for this thread now? "so far, everyone is trying to prove their little points"
                            • DaveHD
                              DaveHD
                              Thrash's argument theoretically holds up, but if you are talking about any modern airplane then it will not hold up. The friction from the landing gear rolling on a conveyor belt is insignificant. Thrash's analogy about holding the car with your arms is a good one, but there is a significant difference in strength between a human's arms and a jet engine.
                              Maybe Orville and Wilbur's plane may have had a tough time taking off on the conveyor. 😛
                              • DaveHD
                                DaveHD
                                Smart people are try to explain to Retards that a plane on a conveyor belt will still take off.
                                :icon_santa:
                                • JN210J
                                  JN210J
                                  JN210
                                  ^lol, good one.
                                  • UsedU
                                    UsedU
                                    Used
                                    Is it a propeller airplane or a jet airplane.. It might have been stated but im not going to go back and read the rest of that..
                                    1996 Kawasaki Ninja ZX6R
                                      for the most part, it doesn't matter if it is a prop/jet/rocket plane.
                                      • JN210J
                                        JN210J
                                        JN210
                                        The wheels can move as fast as possible but the plane will go NO WHERE without AIR lift which is not achieved by sitting still.
                                        • K
                                          K
                                          if the plane is moving, air will be flowing across the wings. it doesnt matter how fast/slow the conveyor or the wheels on the plane are moving.
