  4. Tach wire on an EF civic
11 Posts 5 Posters 1.9k Views
  • JohnWJ Offline
    JohnWJ Offline
    JohnW
    Where can I connect the green signal wire on a tachometer to my EF civic? I know you can connect it to the dizzy but theres got to be a diagnostic port or something closer to connect it to.
    90 Civic DX hatch
    D16a6/y8 mini me
      ECU plugs.
        looking at the ECU, it is the bottom left brown wire on the left black plug.
        • JohnWJ Offline
          JohnWJ Offline
          JohnW
          That wire (B20) is listed as the Ignition Timing Adjusting Connector, is that the right one?
          90 Civic DX hatch
          D16a6/y8 mini me
          • M Offline
            M Offline
            matt j
            have you tried looking at the pin outputs from the links that i gave you on your other post about the mpfi? That may help you also. I know when i did mine in a ef i hooked it up to the tach signal wire on ecu, but that was like 5 years ago now and cant remember which one it was.
              look for a blue wire coming from the dizzy thats what i have always used.
              • JohnWJ Offline
                JohnWJ Offline
                JohnW
                Yep, that was very helpfull. I think I am just going to use the tach signal wire on the cluster harness. Getting the cluster out isn't as much of a pain in the ass as I thought. Hopefully I will be getting a cluster with a tach soon but in the meantime it's an external tach for me (not the huge kind with the obnoxious shift light tho)
                90 Civic DX hatch
                D16a6/y8 mini me
                  just wait till you get a cluster with a tach, they cost like $25-50 tops
                  • JohnWJ Offline
                    JohnWJ Offline
                    JohnW
                    im watching a few on ebay now, hopefully something comes of it. i plan on being able to start the car tomorrow if my parts get here. i'll need to adjust the idle rpm and set the timing ( I fuckin forgot to mark the dizzy position when I took it off) so I'll need to have a tach connected.
                    90 Civic DX hatch
                    D16a6/y8 mini me
                      I bought an si Cluster of bubba for 25 bucks last year... they are even cheaper on ebay. HF ones go for 10 bucks sometimes.
                      • JohnWJ Offline
                        JohnWJ Offline
                        JohnW
                        yeah, I guess they are going at somewhat of a premium then, like 50-100 (no kidding 100) plus shipping. does anyone know if a 91 civic lx cluster will work plug and play? im sick of wiring for a week or two.
                        90 Civic DX hatch
                        D16a6/y8 mini me
