  4. Plane on a conveyor belt
298 Posts 57 Posters 19.2k Views
    No, we are asking what affect a treadmill has on a planes ability to take off. The answer is none.
    • bubbaB
      bubbaB
      GhettoFabulousCRX;203111 wrote:
      no. We're not talking about if it will overcome the speed of the treadmill. We're talking if a plane takes off at lets say 120mph. The conveyor is set at 120. Will the plane raise up and take off. No the plane is matched in speed and in turn is not moving. Zero air is going over or under the wing creating no lift. But then again I could be way the fuck off
      yes u are...
      • inspector01I
        inspector01I
        You got that exactly right (the part about being way the fuck off).....
        • Afsil80A
          Afsil80A
          Afsil80
          -Peter
          1991 240SX
          • zbrownZ
            zbrownZ
            Wow how did i miss this..... the rules of this experiment are vague
            I am not gonna get into the whole conveyor part because you will not change what people think
            there is only one point i want to make
            Lets just disregard the conveyor and say we chain the plane to a stake in the ground behind it, so it cannot move forward at all.....
            1. A prop plane with a enough thrust will lift off the ground even being stationary, if there is enough air moving across the wings from the prop
            2. I dont car what anyone says, a jet/rocket powered plane (even with unlimited thrust) is going nowhere as there is no air being moved across the wings
            3. Gary is a Homo
            • GnArKiLlG
              GnArKiLlG
              GnArKiLl
              its just like a car on a dyno.. strap wings on you car and see if it will fly....................negative
              1976 Chevy K5- lifted beater
              • XJHEADX
                XJHEADX
                How does a VSTOL aircraft take-off????? hmmmmmmm
                  3. Gary is a Homo
                  1. Maybe
                  2. Completely irrelevant to what we are talking about, but yes, a stationary plane will not take off (excluding Harrier, etc...) This plane is NOT stationary however and there is nothing holding it still.
                  3. LOL
                  • zbrownZ
                    zbrownZ
                    Obviously I was talking conventional............hmm .... better clear up the space shuttle and Saturn V will go somewhere to for the smart asses 😉
                    • zbrownZ
                      zbrownZ
                      tjamz;203139 wrote:
                      1. Maybe
                      2. but yes, a stationary plane will not take off
                      I can see how some can be confused though....... the question kind of states that the plane will not move forward in relation to its relative original position
                      atleast someone could take it that way...
                      and you and I both agree a stationary plane is going nowhere, cept what i said about a prop plane
                      Gary is still a homo....
                      • GrrG
                        GrrG
                        fuck U, i think im the only one that actually posted a clear scientific answer in this thread. You can think whatever you want, but the proof is in my post, simple as that.
                        Hey zac, if the plane remains stationary, there is no conveyor belt, and the whole question takes place in the 17th dimension, and ive been there man, its crazy, you dont want to know
                        Gary
                          Actually, it doesn't. It says the plane moves one way and the conveyor moves the other way. It doesn't say the conveyor stops the plane from moving.
                          You'd know better than I would (or so I hear)
                            I basically tried to use simple english to explain what you did with science. Thank you for putting it out there in scientific form though, it was greatly appreciated.
                            • GarageAlchemistG
                              GarageAlchemistG
                              GarageAlchemist
                              AcesHigh;89557 wrote:
                              You are making the assumption that it's the speed of the plane making it take off, and this is incorrect. Speed is all relative. When you are walking inside a moving train with it, you aren't going at 60 miles per hour. You're going at a meter a second.
                              Actually this is inaccurate, as you are moving 60 plus miles an hour, if the train crashed, you'd still be going 60 miles an hour until you hit something.
                              97 GTi, 03 KJ
                              • BassplayerB
                                BassplayerB
                                Bassplayer
                                ^^^^ yeah thats Newtons 1st law. Also if you're in a train and its going 60mph and you're walking 1m/s then depending on the direction of the velocities you're going 60mph+1m/s or 60mph-1m's
                                And Grr I totaly get you're whole physics explanation, I just have too much of a life to sit down and be a scientist. You're science makes sense for the most part its just you're forgetting lift and also Bernoulli's principle. Theres enough thrust to make it fly but there's no lift.
                                1995 GMC Sierra
                                • GarageAlchemistG
                                  GarageAlchemistG
                                  GarageAlchemist
                                  yea, you worded that better than I
                                  97 GTi, 03 KJ
                                  • wesholeW
                                    wesholeW
                                    Hardly the same thing. On a car, the wheels propel the vehicle. On a plane, its the prop or turbine.
                                    • K
                                      K
                                      can you explain why there is no lift?
                                      • bubbaB
                                        bubbaB
                                        ^ exactly...the plane is moving forward at the same speed as it would on a runway same airflow, lift etc...all the conveyor belt does is make the wheels spin twice as fast...so unless the wheels blow and it crashes and burns it will fly, lol
                                        • zbrownZ
                                          zbrownZ
                                          Ha.... I just threw the "Gary is a homo" thing in there to piss you off
                                          I will have to go back and read your physics lesson cuz i didn't read this whole thread
                                          And i still think it is easy for people to be confused and think that the plane cannot/is not moving forward in space
