  4. How much?
How much?
26 Posts 11 Posters 1.2k Views
  • JN210J Offline
    JN210J Offline
    JN210
    So if im just going to turbo my car this summer, how much money would be a safe amount to have saved up? (Im thinkin 2K) .I also would like to get an exhaust from this site......Mine is shot......the one im lookin at is 800 some, but the main question is "How much is a good amount to keep in store for this project?"
    http://www.cmperformanceexhaust.com/
    Thanks
    Jeff
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
      I would say closer to 3500.00 would be a safer figure. That's if you want it done right. Without cuting corners and cheaping out here and there.
      • JN210J Offline
        JN210J Offline
        JN210
        I dont want anything half-assed.....I want it done right the first time, The people who are gonna be helpin me with this are My brother and dad....My dad has rebuilt an entire truck before so he is a good "asset" you could say and my brother....well....he is just there to turn some bolts lol.
          Save up as much as you can. So you can get parts that you want and need. And just start with the OEM Z31 turbo kit and get your manual swap done.
          $800 is a rip off for an exhaust. Just get one made at the exhaust shop. You will be fine with a 3 inch turbo back with non mandrel pipe. As you well not be making extreme numbers.
          You already have lots of the parts.
          What are you using for EMS, and all that. Dyno tuning is around 125-150 an hour.
          • BassplayerB Offline
            BassplayerB Offline
            Bassplayer
            Realisticaly you're looking at at least $4,000 start to finish. Got to an exhaust shop and get a 3" turbo back done. Most places have a mandrel bender so get mandrel bended pipe if you can.
            1995 GMC Sierra
              ^LOL!
              Like nobody has a madrel bender.
              JN, what exactly are you planning now??????? I though you were just going to use all the stock Z31 turbo parts with a couple extras.
              • JN210J Offline
                JN210J Offline
                JN210
                ok, I have EVERYTHING needed to do this conversion....I could do it now if I wanted to but I also need me a new exhaust.....just wondering....who can do a good exhaust for me?.....So all I need is the money and exhaust, Also, I need a T5 tranny from a 5-speed z31 (if I want to do the swap) I also have all the parts for the manual swap too (just need the tranny) Im all set as far as parts goes.....its the money and time thing.
                  Figure out the cost of everything you need, and i mean everything including gaskets, tuning, and all the stuff commonly forgotten. Then add another 50% to that, and assume that is atleast how much you will end up spending.
                    BassplayerB Offline
                    Bassplayer
                    Well i went to 3 different shops and they had mandrel benders.......... soooooooo idk. But for turbo stuff I'd take it to SLS he'd do the best job.
                    1995 GMC Sierra
                      ok, so here is what i need to know:
                      List every single part you have
                      List every part you need
                      and since your in there,
                      timing belt
                      plugs
                      wires
                      cap and rotor
                      clutch
                      also have about 3-400$ around for new hoses and all that stuff if its needed, so you arent sitting and waiting
                      and there are cheaper places to get the exhaust parts, if buying new, just get the downpipe, or get the $530 full system with no cat. WTF are you looking at stainless systems for anyway? waste of $$
                        If u want ur car there for a long time...
                          There are shops that say they have mandrel benders. But then have no clue what a mandrel bend is. Exhaust pros is the only place I know for sure may have one.
                          SLS doesnt have one even for the amount of IC pipes and exhaust he has done, its more cost effective to buy premade bends. I did my Downpipe back exhaust for just over $200 including all the piping, muffler and someone to weld it/install.
                          • JN210J Offline
                            JN210J Offline
                            JN210
                            ok, A lsit of parts I have (If you want pics just ask and I will show what I have)
                            T3 Turbocharger and exhaust elbow from 84-87 300ZX Turbo
                            Drivers side exhaust manifold
                            Downpipe
                            Front crossmember
                            Drivers side engine mount bracket
                            All intake piping
                            Alternator mount, tensioner
                            Turbo oil lines and water lines
                            Fuel injectors (260cc/min instead of 180cc/min)
                            Correct ECU (mine is from an 86 Turbo)
                            #All parts for manual swap
                            What I need
                            All applicable gaskets
                            Exhaust system
                            Tranny from 5-speed Z
                              All depends on what you want to do........
                              are you doing a stock turbo + manifolds?........... cheap
                              or a full setup with aftermarket manifolds and stuff?.......... more expensive
                              are you doing everything yourself?
                              I mean everything by your self?
                              4k on a turbo setup... damn
                              i could stretch 2k along ways...........
                              I dont have more than 3k into my powerplant counting the standalone, turbo, engine, manifolds, ect.........thats a $1200 standalone byitself
                                from what you said above..... if you did it yourself, 2k would do it easy.......... shop around and you could get all the stuff for less than a grand.......
                                You can buy a complete beautiful compound twins setup for a cummins for 4k
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  yeah I will be doing everything by myself (with the addition of my dad and 'josh) I am not sure about the exhaust though...may have someone else do that.
                                    since you have the stock downpipe, it will hook right up to your stock exhaust. Save your money on that for now, just hollow out the cat.
                                    Also yours is an 88, so the alternator is already in the right spot.
                                    So, get a set of exhaust gaskets
                                    timing belt
                                    t-belt tensioner? ill have to check if its needed, dont remember
                                    ignition stuff
                                    upper intake gasket
                                    new FI hose for feed/return and injectors
                                    do you have a top, or side-feed fuel rails?
                                    injector seals (bottom)
                                    trans
                                    that should take care of most of it, once all that shit is done you can start upgrading it later. DO NOT spend time and money upgrading to bigger/better stuff until the car is driveable with the manual with stock stuff. Also i would do a full emmissions delete on that intake, it clears up tons of room.
                                    Gary
                                    • kylushK Offline
                                      kylushK Offline
                                      kylush
                                      for my turbo setup i'll be inbetween 2-3k
                                      1998 Z28 Camaro
                                        listen to what gary just said. stock first so you can work on problems.
                                        • JN210J Offline
                                          JN210J Offline
                                          JN210
                                          Alright, Gary im sure has a history of knowing his shit, thanks for the help man. I will definitely be willing to do the essentials for now....the only thing wrong with my exhaust really is that the muffler is ripped open....I just need someone to seal it up...The injectors I believe are top feed. I am not so sure on how to clear up the intake....I have no idea how to do that...
