  4. How much?
How much?
26 Posts 11 Posters 1.5k Views
  • JN210J Offline
    JN210J Offline
    JN210
    ok, I have EVERYTHING needed to do this conversion....I could do it now if I wanted to but I also need me a new exhaust.....just wondering....who can do a good exhaust for me?.....So all I need is the money and exhaust, Also, I need a T5 tranny from a 5-speed z31 (if I want to do the swap) I also have all the parts for the manual swap too (just need the tranny) Im all set as far as parts goes.....its the money and time thing.
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
      Figure out the cost of everything you need, and i mean everything including gaskets, tuning, and all the stuff commonly forgotten. Then add another 50% to that, and assume that is atleast how much you will end up spending.
      • BassplayerB Offline
        BassplayerB Offline
        Bassplayer
        Well i went to 3 different shops and they had mandrel benders.......... soooooooo idk. But for turbo stuff I'd take it to SLS he'd do the best job.
        1995 GMC Sierra
          ok, so here is what i need to know:
          List every single part you have
          List every part you need
          and since your in there,
          timing belt
          plugs
          wires
          cap and rotor
          clutch
          also have about 3-400$ around for new hoses and all that stuff if its needed, so you arent sitting and waiting
          and there are cheaper places to get the exhaust parts, if buying new, just get the downpipe, or get the $530 full system with no cat. WTF are you looking at stainless systems for anyway? waste of $$
            If u want ur car there for a long time...
              There are shops that say they have mandrel benders. But then have no clue what a mandrel bend is. Exhaust pros is the only place I know for sure may have one.
              SLS doesnt have one even for the amount of IC pipes and exhaust he has done, its more cost effective to buy premade bends. I did my Downpipe back exhaust for just over $200 including all the piping, muffler and someone to weld it/install.
              • JN210J Offline
                JN210J Offline
                JN210
                ok, A lsit of parts I have (If you want pics just ask and I will show what I have)
                T3 Turbocharger and exhaust elbow from 84-87 300ZX Turbo
                Drivers side exhaust manifold
                Downpipe
                Front crossmember
                Drivers side engine mount bracket
                All intake piping
                Alternator mount, tensioner
                Turbo oil lines and water lines
                Fuel injectors (260cc/min instead of 180cc/min)
                Correct ECU (mine is from an 86 Turbo)
                #All parts for manual swap
                What I need
                All applicable gaskets
                Exhaust system
                Tranny from 5-speed Z
                  All depends on what you want to do........
                  are you doing a stock turbo + manifolds?........... cheap
                  or a full setup with aftermarket manifolds and stuff?.......... more expensive
                  are you doing everything yourself?
                  I mean everything by your self?
                  4k on a turbo setup... damn
                  i could stretch 2k along ways...........
                  I dont have more than 3k into my powerplant counting the standalone, turbo, engine, manifolds, ect.........thats a $1200 standalone byitself
                    from what you said above..... if you did it yourself, 2k would do it easy.......... shop around and you could get all the stuff for less than a grand.......
                    You can buy a complete beautiful compound twins setup for a cummins for 4k
                    • JN210J Offline
                      JN210J Offline
                      JN210
                      yeah I will be doing everything by myself (with the addition of my dad and 'josh) I am not sure about the exhaust though...may have someone else do that.
                        since you have the stock downpipe, it will hook right up to your stock exhaust. Save your money on that for now, just hollow out the cat.
                        Also yours is an 88, so the alternator is already in the right spot.
                        So, get a set of exhaust gaskets
                        timing belt
                        t-belt tensioner? ill have to check if its needed, dont remember
                        ignition stuff
                        upper intake gasket
                        new FI hose for feed/return and injectors
                        do you have a top, or side-feed fuel rails?
                        injector seals (bottom)
                        trans
                        that should take care of most of it, once all that shit is done you can start upgrading it later. DO NOT spend time and money upgrading to bigger/better stuff until the car is driveable with the manual with stock stuff. Also i would do a full emmissions delete on that intake, it clears up tons of room.
                        Gary
                        • kylushK Offline
                          kylushK Offline
                          kylush
                          for my turbo setup i'll be inbetween 2-3k
                          1998 Z28 Camaro
                            listen to what gary just said. stock first so you can work on problems.
                            • JN210J Offline
                              JN210J Offline
                              JN210
                              Alright, Gary im sure has a history of knowing his shit, thanks for the help man. I will definitely be willing to do the essentials for now....the only thing wrong with my exhaust really is that the muffler is ripped open....I just need someone to seal it up...The injectors I believe are top feed. I am not so sure on how to clear up the intake....I have no idea how to do that...
                                gary and jason would be able to help you on that. And, I can get you a OEM muffler and install it i believe.
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  I would appreciate that very much.
                                    Just replace the tip, i hear APC makes nice tips.
                                    • JN210J Offline
                                      JN210J Offline
                                      JN210
                                      mmmm.......there isnt anything wrong with the tip...its the muffler, there is a opening on the side of it...so it rattles....badly.
                                        well most ppl think sls is a storage space, untill they can save up money to buy the parts they want done....:icon_scratch:
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          JN210;205163 wrote:
                                          So if im just going to turbo my car this summer, how much money would be a safe amount to have saved up? (Im thinkin 2K) .I also would like to get an exhaust from this site......Mine is shot......the one im lookin at is 800 some, but the main question is "How much is a good amount to keep in store for this project?"
                                          http://www.cmperformanceexhaust.com/
                                          Thanks
                                          Jeff
                                          Stock exhaust is 2 inch :icon_puke_r:
                                          I'm going to get the CM Z-172, and the Z-175. Then make a test pipe and
                                          install a oval Magnaflow muffler. :icon_cheers:
