  4. How much?
How much?
26 Posts 11 Posters 1.3k Views
  • JN210J Offline
    JN210J Offline
    JN210
    ok, A lsit of parts I have (If you want pics just ask and I will show what I have)
    T3 Turbocharger and exhaust elbow from 84-87 300ZX Turbo
    Drivers side exhaust manifold
    Downpipe
    Front crossmember
    Drivers side engine mount bracket
    All intake piping
    Alternator mount, tensioner
    Turbo oil lines and water lines
    Fuel injectors (260cc/min instead of 180cc/min)
    Correct ECU (mine is from an 86 Turbo)
    #All parts for manual swap
    What I need
    All applicable gaskets
    Exhaust system
    Tranny from 5-speed Z
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
      All depends on what you want to do........
      are you doing a stock turbo + manifolds?........... cheap
      or a full setup with aftermarket manifolds and stuff?.......... more expensive
      are you doing everything yourself?
      I mean everything by your self?
      4k on a turbo setup... damn
      i could stretch 2k along ways...........
      I dont have more than 3k into my powerplant counting the standalone, turbo, engine, manifolds, ect.........thats a $1200 standalone byitself
        from what you said above..... if you did it yourself, 2k would do it easy.......... shop around and you could get all the stuff for less than a grand.......
        You can buy a complete beautiful compound twins setup for a cummins for 4k
        • JN210J Offline
          JN210J Offline
          JN210
          yeah I will be doing everything by myself (with the addition of my dad and 'josh) I am not sure about the exhaust though...may have someone else do that.
            since you have the stock downpipe, it will hook right up to your stock exhaust. Save your money on that for now, just hollow out the cat.
            Also yours is an 88, so the alternator is already in the right spot.
            So, get a set of exhaust gaskets
            timing belt
            t-belt tensioner? ill have to check if its needed, dont remember
            ignition stuff
            upper intake gasket
            new FI hose for feed/return and injectors
            do you have a top, or side-feed fuel rails?
            injector seals (bottom)
            trans
            that should take care of most of it, once all that shit is done you can start upgrading it later. DO NOT spend time and money upgrading to bigger/better stuff until the car is driveable with the manual with stock stuff. Also i would do a full emmissions delete on that intake, it clears up tons of room.
            Gary
            • kylushK Offline
              kylushK Offline
              kylush
              for my turbo setup i'll be inbetween 2-3k
              1998 Z28 Camaro
                listen to what gary just said. stock first so you can work on problems.
                • JN210J Offline
                  JN210J Offline
                  JN210
                  Alright, Gary im sure has a history of knowing his shit, thanks for the help man. I will definitely be willing to do the essentials for now....the only thing wrong with my exhaust really is that the muffler is ripped open....I just need someone to seal it up...The injectors I believe are top feed. I am not so sure on how to clear up the intake....I have no idea how to do that...
                    gary and jason would be able to help you on that. And, I can get you a OEM muffler and install it i believe.
                    • JN210J Offline
                      JN210J Offline
                      JN210
                      I would appreciate that very much.
                        Just replace the tip, i hear APC makes nice tips.
                        • JN210J Offline
                          JN210J Offline
                          JN210
                          mmmm.......there isnt anything wrong with the tip...its the muffler, there is a opening on the side of it...so it rattles....badly.
                            bubba;205224 wrote:
                            If u want ur car there for a long time...
                            well most ppl think sls is a storage space, untill they can save up money to buy the parts they want done....:icon_scratch:
                            • z31Z Offline
                              z31Z Offline
                              z31
                              JN210;205163 wrote:
                              So if im just going to turbo my car this summer, how much money would be a safe amount to have saved up? (Im thinkin 2K) .I also would like to get an exhaust from this site......Mine is shot......the one im lookin at is 800 some, but the main question is "How much is a good amount to keep in store for this project?"
                              http://www.cmperformanceexhaust.com/
                              Thanks
                              Jeff
                              Stock exhaust is 2 inch :icon_puke_r:
                              I'm going to get the CM Z-172, and the Z-175. Then make a test pipe and
                              install a oval Magnaflow muffler. :icon_cheers:
