  4. How much?
How much?
26 Posts 11 Posters 1.5k Views
    since you have the stock downpipe, it will hook right up to your stock exhaust. Save your money on that for now, just hollow out the cat.
    Also yours is an 88, so the alternator is already in the right spot.
    So, get a set of exhaust gaskets
    timing belt
    t-belt tensioner? ill have to check if its needed, dont remember
    ignition stuff
    upper intake gasket
    new FI hose for feed/return and injectors
    do you have a top, or side-feed fuel rails?
    injector seals (bottom)
    trans
    that should take care of most of it, once all that shit is done you can start upgrading it later. DO NOT spend time and money upgrading to bigger/better stuff until the car is driveable with the manual with stock stuff. Also i would do a full emmissions delete on that intake, it clears up tons of room.
    Gary
    • kylushK Offline
      kylushK Offline
      kylush
      for my turbo setup i'll be inbetween 2-3k
      1998 Z28 Camaro
        listen to what gary just said. stock first so you can work on problems.
        • JN210J Offline
          JN210J Offline
          JN210
          Alright, Gary im sure has a history of knowing his shit, thanks for the help man. I will definitely be willing to do the essentials for now....the only thing wrong with my exhaust really is that the muffler is ripped open....I just need someone to seal it up...The injectors I believe are top feed. I am not so sure on how to clear up the intake....I have no idea how to do that...
          *1989 Nissan 300ZX Z31 *
          > DelSlow;262050 wrote:
          > I like the new JN210
            gary and jason would be able to help you on that. And, I can get you a OEM muffler and install it i believe.
            • JN210J Offline
              JN210J Offline
              JN210
              I would appreciate that very much.
                Just replace the tip, i hear APC makes nice tips.
                • JN210J Offline
                  JN210J Offline
                  JN210
                  mmmm.......there isnt anything wrong with the tip...its the muffler, there is a opening on the side of it...so it rattles....badly.
                    bubba;205224 wrote:
                    If u want ur car there for a long time...
                    well most ppl think sls is a storage space, untill they can save up money to buy the parts they want done....:icon_scratch:
                    • z31Z Offline
                      z31Z Offline
                      z31
                      JN210;205163 wrote:
                      So if im just going to turbo my car this summer, how much money would be a safe amount to have saved up? (Im thinkin 2K) .I also would like to get an exhaust from this site......Mine is shot......the one im lookin at is 800 some, but the main question is "How much is a good amount to keep in store for this project?"
                      http://www.cmperformanceexhaust.com/
                      Thanks
                      Jeff
                      Stock exhaust is 2 inch :icon_puke_r:
                      I'm going to get the CM Z-172, and the Z-175. Then make a test pipe and
                      install a oval Magnaflow muffler. :icon_cheers:
