its almost....
looks good parker!
how low is the front sitting with the motor in it now?
Parker;205503 wrote:
Parker i have a little project that would take about an hr and would look baller..........
remove the booster..... make a plate/rod...... move it up to change the lever ratio to make up for the lack of a booster....... = looks dope shit
brakes feel awsome and can easily be locked up......
If you were interested there are a couple easy things i could point out and it would take literally an hr to do
zbrown;205591 wrote:
Parker i have a little project that would take about an hr and would look baller..........remove the booster..... make a plate/rod...... move it up to change the lever ratio to make up for the lack of a booster....... = looks dope shit
ha, i have been thinking about what to do about brakes, the motor barely pulls enough vaccum for the booster, so yeah if you want to shoot me a PM i would like to know how to do this.... that would free up alot of space
carb is all mounted up, had to order a holley blue pump and a new promaster starter.... also ordered some billet holly brackets and that mount to the side of the carb for the pressure regulator and throttle cable..... parts may be here friday... should have it running in about two weeks..
