  3. Track Talk
  4. How fast will your car be in 2008?
180 Posts 62 Posters 28.7k Views
    oh and mid 10s or bust...
    so.... bust....
      ill be as fast as an NA 7 with an open diff will be with little mods done to it!
      • capitljC Offline
        capitljC Offline
        capitlj
        Slow but slow > fast right. I have a built tranny on the line and we shall see if I can find an 8.8 for the right price the one I was looking at got sold. If I get everything working correctly mid to low 15's with my big ass driving.
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          turtle slow?
            i'm thinking somewhere in the 12's with the s2000 as long as the rear diff hold.....
            and the wagon should be solid 14's
              if i still have the MR2, low 14's high 13 on street tires...need bout 500 bux in mods (sc14 s/c, 180mm pulley kit, and gruntbox) and cross my fingers the stock clutch holds up...I think it will but you never know...the thing does have 183k miles on it lol. And if time and/or money permits another $400-500 in spending then i may get a JDM LSD trans too...but knowing me idk if i'll still have it this summer lol.
              • Afsil80A Offline
                Afsil80A Offline
                Afsil80
                16's for you it is.
                -Peter
                1991 240SX
                  zbrown;207326 wrote:
                  I need to get the th350 auto done in my car so i don't blow my tranny up with a grenade from being pist as shit the next time i race.
                  Thats an excellent idea, your car will fly with a well set up auto trans. 🙂 Just don't hit it with a transbrake and the rear end should hold up.
                  My car... well it's going to go really stinking fast this year. Faster than Faul anyway.
                  :icon_porc:
                  • 2wheeler2 Offline
                    2wheeler2 Offline
                    2wheeler
                    It's not a car, but, with proper gearing I'd assume the 1000 would be in the mid 190s. Faster than Dave anyway. 🙂
                    '08 Suzuki Hayabusa
                    '09 Yamaha Zuma 200cc
                    '95 E-350 7.5L
                      Mid 190's?
                      First- you'd have to find someone else to ride it because I know you are too skeerd to go that fast. 🙂
                      Second - you'll need to be going downhill with a 30 mph tailwind with the HP your bike makes.
                      Third - "with proper gearing" in my car you'd be a speck in my rearview mirror.
                      :stirpot:
                      • 2wheeler2 Offline
                        2wheeler2 Offline
                        2wheeler
                        So the question is.....will you put $$$ down that I can't make a GPS run in the 190s?
                        How long does it take you to install "proper gearing"? I'll need about 20 minutes from the time I'm back in the pits after a 1/4 mile run and I'll be ready.
                        :stirpot:
                        '08 Suzuki Hayabusa
                        '95 E-350 7.5L
                        • BassplayerB Offline
                          BassplayerB Offline
                          Bassplayer
                          :stirpot:
                          How do you put new gearing in a bike that fast?
                          Also not a car, but i'm hoping for 12's on the SV. Anything faster and its too hard to hangon lol
                          1995 GMC Sierra
                          • 2wheeler2 Offline
                            2wheeler2 Offline
                            2wheeler
                            1. Put the bike on a rear stand.
                            2. Loosen chain.
                            3. Pull rear axle.
                            4. Remove/replace 5 nuts and your rear sprocket is changed. Its quicker if you have a spare sprocket carrier with the new sprocket mounted, then you just swap carriers.
                            5. Loosen left fairing.
                            6. Pull counter sprocket cover off.
                            7. Put bike in gear.
                            8. Remove replace counter sprocket nut and front sprocket is changed.
                            9. Replace rear wheel/chain/counter sprocket cover.
                            10. Tighten chain.
                            11. Tighten axle nut.
                            If you have all the tools in front of you and are really trying to move quickly....takes bout 20 minutes.
                            '08 Suzuki Hayabusa
                            '95 E-350 7.5L
                              :icon_porc:
                              Between trying to jam gears and waiting a 1/2 hr for boost between shifts i am done with the 5-speed............ I'd do a dogbox, but $$$$
                              DaveH;207394 wrote:
                              Mid 190's?
                              :stirpot:
                              True.....
                              Bikes are a brick in the wind............
                              I have even done a full 5th pull till hard rev cut and the math works out to 205 mph........... this was on the new US 12 so i didn't die
                                The quote was mid-190's so lets just round it off to an even 195mph on the GPS. I'll def put the $$ down... I just hope we can capture the event on video so we can see the urine running out of the pant leg of your leathers as you get anywhere near 180, much less 195. :icon_cheers:
                                How long does it take you to install "proper gearing"? I'll need about 20 minutes from the time I'm back in the pits after a 1/4 mile run and I'll be ready. :stirpot:
                                I'm not really sure that it matters how long it would take me to change gearing. I can run top speed gearing at the drag strip and still run quicker than your bike when it has 1/4 mile gearing in it.:stirpot::stirpot::stirpot:
                                • 2wheeler2 Offline
                                  2wheeler2 Offline
                                  2wheeler
                                  Yes, bikes are a brick in the wind. lol Thats why they are all electronically limited to 184 MPH. Thats why the '99-00 Busa can pull 196MPH out of the box due to no speed limiter.
                                  How fast to average cars go out of the box? (No BS $250,000 cars now.)
                                  lol...."the math"....lol
                                  What do you own that can do 205?(I'm assuming you're talking about your 7?)
                                  What is a "full 5th pull"? Are you talking about on a dyno?
                                  '08 Suzuki Hayabusa
                                  '95 E-350 7.5L
                                    BassplayerB Offline
                                    Bassplayer
                                    2. Loosen chain.
                                    3. Pull rear axle.
                                    10. Tighten chain.
                                    lol i thought you were talking about redoing the whole tranny gearing, didn't even think of that.
                                    1995 GMC Sierra
                                      Look at the drag coefficient of a bike once......... it is not very good
                                      It should do 200mph even with a shit DC cuz what is the power:weight??
                                      Ill bet your bike than my car will do 200+ on 15psi, bring the GPS and come for a ride if you aren't scared........
                                      .719 5th ratio
                                      4.11 rear ratio
                                      275/45/17 tires
                                      7500 rpm limit............
                                      do the math
                                      I have hit the limiter twice in 5th gear.......... dont believe me? bring your GPS and your title..........
                                        Since you think you are so funny...........
                                        here is a link to help you out since math > you
                                        http://www.kabamus.com/garage/gears.html
                                          word, i completely beleive it. Hell my GTO did 189 with only 363whp, i would hope you can do at least that with as much power and a solid 1000lbs less weight! (BTW, i own a x-band radar gun, so yes, it was accurate)
                                          lets see
                                          .84 5th gear
                                          3.46 rear
                                          245/45-17 tire
                                          7190rpm
                                          According to the calculator, 7000rpm is 184, and 7500 is 197, so id say i am correct
                                          zac>me though
