  3. Track Talk
  4. How fast will your car be in 2008?
180 Posts 62 Posters 27.9k Views
    zbrown;207326 wrote:
    I need to get the th350 auto done in my car so i don't blow my tranny up with a grenade from being pist as shit the next time i race.
    Thats an excellent idea, your car will fly with a well set up auto trans. 🙂 Just don't hit it with a transbrake and the rear end should hold up.
    My car... well it's going to go really stinking fast this year. Faster than Faul anyway.
    :icon_porc:
    • 2wheeler2 Offline
      2wheeler2 Offline
      2wheeler
      It's not a car, but, with proper gearing I'd assume the 1000 would be in the mid 190s. Faster than Dave anyway. 🙂
      '08 Suzuki Hayabusa
      '09 Yamaha Zuma 200cc
      '95 E-350 7.5L
        Mid 190's?
        First- you'd have to find someone else to ride it because I know you are too skeerd to go that fast. 🙂
        Second - you'll need to be going downhill with a 30 mph tailwind with the HP your bike makes.
        Third - "with proper gearing" in my car you'd be a speck in my rearview mirror.
        :stirpot:
        • 2wheeler2 Offline
          2wheeler2 Offline
          2wheeler
          So the question is.....will you put $$$ down that I can't make a GPS run in the 190s?
          How long does it take you to install "proper gearing"? I'll need about 20 minutes from the time I'm back in the pits after a 1/4 mile run and I'll be ready.
          :stirpot:
          '08 Suzuki Hayabusa
          '95 E-350 7.5L
          • BassplayerB Offline
            BassplayerB Offline
            Bassplayer
            :stirpot:
            How do you put new gearing in a bike that fast?
            Also not a car, but i'm hoping for 12's on the SV. Anything faster and its too hard to hangon lol
            1995 GMC Sierra
            • 2wheeler2 Offline
              2wheeler2 Offline
              2wheeler
              1. Put the bike on a rear stand.
              2. Loosen chain.
              3. Pull rear axle.
              4. Remove/replace 5 nuts and your rear sprocket is changed. Its quicker if you have a spare sprocket carrier with the new sprocket mounted, then you just swap carriers.
              5. Loosen left fairing.
              6. Pull counter sprocket cover off.
              7. Put bike in gear.
              8. Remove replace counter sprocket nut and front sprocket is changed.
              9. Replace rear wheel/chain/counter sprocket cover.
              10. Tighten chain.
              11. Tighten axle nut.
              If you have all the tools in front of you and are really trying to move quickly....takes bout 20 minutes.
              '08 Suzuki Hayabusa
              '95 E-350 7.5L
                :icon_porc:
                Between trying to jam gears and waiting a 1/2 hr for boost between shifts i am done with the 5-speed............ I'd do a dogbox, but $$$$
                DaveH;207394 wrote:
                Mid 190's?
                :stirpot:
                True.....
                Bikes are a brick in the wind............
                I have even done a full 5th pull till hard rev cut and the math works out to 205 mph........... this was on the new US 12 so i didn't die
                  The quote was mid-190's so lets just round it off to an even 195mph on the GPS. I'll def put the $$ down... I just hope we can capture the event on video so we can see the urine running out of the pant leg of your leathers as you get anywhere near 180, much less 195. :icon_cheers:
                  How long does it take you to install "proper gearing"? I'll need about 20 minutes from the time I'm back in the pits after a 1/4 mile run and I'll be ready. :stirpot:
                  I'm not really sure that it matters how long it would take me to change gearing. I can run top speed gearing at the drag strip and still run quicker than your bike when it has 1/4 mile gearing in it.:stirpot::stirpot::stirpot:
                  • 2wheeler2 Offline
                    2wheeler2 Offline
                    2wheeler
                    Yes, bikes are a brick in the wind. lol Thats why they are all electronically limited to 184 MPH. Thats why the '99-00 Busa can pull 196MPH out of the box due to no speed limiter.
                    How fast to average cars go out of the box? (No BS $250,000 cars now.)
                    lol...."the math"....lol
                    What do you own that can do 205?(I'm assuming you're talking about your 7?)
                    What is a "full 5th pull"? Are you talking about on a dyno?
                    '08 Suzuki Hayabusa
                    '95 E-350 7.5L
                      BassplayerB Offline
                      Bassplayer
                      2. Loosen chain.
                      3. Pull rear axle.
                      10. Tighten chain.
                      lol i thought you were talking about redoing the whole tranny gearing, didn't even think of that.
                      1995 GMC Sierra
                        Look at the drag coefficient of a bike once......... it is not very good
                        It should do 200mph even with a shit DC cuz what is the power:weight??
                        Ill bet your bike than my car will do 200+ on 15psi, bring the GPS and come for a ride if you aren't scared........
                        .719 5th ratio
                        4.11 rear ratio
                        275/45/17 tires
                        7500 rpm limit............
                        do the math
                        I have hit the limiter twice in 5th gear.......... dont believe me? bring your GPS and your title..........
                          Since you think you are so funny...........
                          here is a link to help you out since math > you
                          http://www.kabamus.com/garage/gears.html
                            word, i completely beleive it. Hell my GTO did 189 with only 363whp, i would hope you can do at least that with as much power and a solid 1000lbs less weight! (BTW, i own a x-band radar gun, so yes, it was accurate)
                            lets see
                            .84 5th gear
                            3.46 rear
                            245/45-17 tire
                            7190rpm
                            According to the calculator, 7000rpm is 184, and 7500 is 197, so id say i am correct
                            zac>me though
                            • 2wheeler2 Offline
                              2wheeler2 Offline
                              2wheeler
                              Ok Zac, calm down, I will bow down to your "ballerness".
                              No, I won't bet my bike. (I'm assuming if I would I get your 7? Unfortunately, I don't want your 7.) Like I hinted at above, I do not "ball" like you.
                              I will, however do a cash wager on your car's 200 MPH run. The wager will be a number we agree on. If you tell me that you won't do it for less than $X, then I will take that as you buying your way out of the bet. I will make sure that it pays for your time and gas.
                              I will be in the car. Do you have a datalogger for your boost?
                              I'm excited to see you run 200.
                              '08 Suzuki Hayabusa
                              '95 E-350 7.5L
                              • ruthless351R Offline
                                ruthless351
                                I hope to run mid to high13's with the new goodies on the stang. We shall see though.
                                • fallguyF Offline
                                  fallguyF Offline
                                  fallguy
                                  :icon_porc:
                                  Hopefully your car will at least run 8's....that's so last year. 😉
                                  Both our cars will stink....like popcorn.
                                  Ethan....remember to make sure you pick a road that's wide enough to fit two cars and your bike on your 195 attempt. We'll make sure to stay ahead so your urnine that is coming out of your leathers pant leg won't get on our tires and make us crash. 🙂
                                  1990 Ford Probe GT 2jz RWD
                                    Ha look at your last post..... yeah i am trying to be "baller" Id say you have a stick up your ass trying to act all tough guy with what that las post said
                                    Its alight.... jealousy is a human characteristic ..... i wouldn't want you too look good driving something. Id rather see you look like a homo overweight on your rocket trying to impress people with an engine strapped between your legs
                                    Hmm lets see..... I have a full standalone..... nope no way to datalog
                                    I will be in the car. .
                                    I dont want you to piss yourself on my seat
                                      A car that is stock that runs 16's then modded to run 11's is >>>>>>>>>> a bike that runs 9's stock and then modded to run low 9's
                                      Hmm i wonder why cars have a much easier time working bikes from races at higher speeds.......... hmmm no way aero has anything to do with it
                                      sorry Math > you
                                      I have a problem trying to figure where you don't comprehend........... that the I dont have enough power or you just don't understand mathematical formulas for shit
                                      BIKER BOYS ASSEMBLE............
                                        "Grabs some more popcorn".
                                        This is gettin expensive. I have been buying alot of popcorn lately. We need spring.
                                        • BuniqueB Offline
                                          BuniqueB Offline
                                          Bunique
                                          I still got left over popcorn from my last thread.
