  4. rev limiter issue
rev limiter issue
7 Posts 7 Posters 620 Views
  • theobliviousT Offline
    theoblivious
    So i got in a debate with my friend on rev limiter and speeds. He says that if you increase the compression of an engine that your going to get a higher top speed per gear. I said no that cant be true because your still limited by that gear speed and rev limiter (assuming the gear has a rev limiter). you may get to that speed faster but that is the fastest you will go in that gear.
    correct me if i am wrong. ii am a newb.
    BOOST....to be continued
      no your freind is an idiot....
        you own him.
        Higher compression would get you there faster, or it can also blow it up faster.
          lol your freind is funny
          • Krazy_KlingK Offline
            Krazy_Kling
            i'd have to say that your friend fails at knowing things about engines
            Jordan
            02 CBR600 F4i
            96 Nissan 200SX
            90 Nissan Sentra
            87 Honda Helix
            > SPANISH-RICE;209867 wrote:
              failure > friend
              • D Offline
                D Offline
                dynotune
                depends on how you look at it... If there is no rev limiter or it is high, higher compression CAN extend the powerband of the engine, allowing for more RPMs, allowing for more MPH, but it would depend on the context of your conversation and vehicle at hand.
                DynoTune Speed & Performance
                Mobile chassis dyno service
                www.dynotuneusa.com
                (605) 753-1101
