  2. Introductions
  3. Introductions
  4. fargostreet boot
fargostreet boot
43 Posts 18 Posters 1.6k Views
  • fdfreakF Offline
    fdfreakF Offline
    fdfreak
    zbrown,
    Man I am not doubting you at all. Im sure you can rebuild a good engine. I am just trusting the guy that build mine when I was stationed in Okinawa japan. He has rebuilt over 50 engines himself inculding a few 3 rotors. He said that it needs to be broke in with the new rotor housings, just until the compression comes up. This guy in my opinion is more knowledgable than most of the rotory shop guys. His street ported motors were producing about 430 hp with a T04S, where the guys here in the states are only at 380.
    Now apriciate you telling me how much you know about rotories. I am sure you know alot more than me. and I can garauntee that I will probably ask you for advise in the future, but for now I am going to do what I was told and break in the engine.
    I didnt pay no $5k for a the engine. I payed and even 3k. And that is with new rotor housings, aggressive street port, and 2mm apex seals.
    12.645@118mph 12.6psi
    • fdfreakF Offline
      fdfreakF Offline
      fdfreak
      btleier,
      I think I might be taking a trip down to either banzai racing in IN or RX7 store in OH. What do you mean by parts? ecu, turbo, engine?
      btleier;208882 wrote:
      welcome to the site man. good to see the progress. who you going to have tune it, and what kinda parts you going with?
      • 99civic9 Offline
        99civic9 Offline
        99civic
        Welcome i seen your ride in TM. look nice
        2000 civic SiR - jdm sickness
          Dude i wasnt ripping on you.......
          there is just abunch of garbage thrown around out there when it comes to these engines and what is right.
          sounds like you got set up with a good guy.
          dont tear up those new housings, I would even feel bad 😉
          • fdfreakF Offline
            fdfreakF Offline
            fdfreak
            No, I know you werent. Thanks for the welcome. Im sure ill see you around this spring. It will be nice to talk to another rotor head.
              ..... V8 .....
              ok im done now...
                fdfreak;208947 wrote:
                No, I know you werent. Thanks for the welcome. Im sure ill see you around this spring. It will be nice to talk to another rotard* head.
                fixed*
                  what are you goals. how big is the t04s, I'm not familiar. I made 423whp at 17psi on my t67 with stock ports.
                    Blake, I think he is using a t04Z, so same as a t04R (pt67) but dual BB
                    • fdfreakF Offline
                      fdfreakF Offline
                      fdfreak
                      Yea, Zach's right. I am using a T04Z from atpturbo.com. I only said T04S to use it as a reference. But my goal is around the 430-450 @ 16 psi. I should be pretty close.
                      • fdfreakF Offline
                        fdfreakF Offline
                        fdfreak
                        btleier, Are you selling yours? I thought I heard that a guy from Minot was selling his FD.
                          yeah. I'd like to. if my turbo would quit shitting on me. off to precision for another rebuilt 60.2 miles after the last one they did for me.
                            wow are you fucking serious??
                            they must be covering it huh?? how did it shit? bearings, or seals?
                              Parker;209010 wrote:
                              ..... SBF .....
                              ok im done now...
                              fix.t
                                MisterCMK;209208 wrote:
                                fix.t
                                why would you put a less reliable motor in there?
                                  not exactly... I don't know exactly how to explain it, but the bolt or stud that goes through the middle, with the washers and stuff on it (threads through the whole center cartridge from what I can tell) fell out or off. and there's all kinds of shaft play. no chunks missing from the wheel so who knows. it just happened this last weekend, and I haven't talked to them yet, but they better cover it, or I'm going to slit their throats.
                                    One word.
                                    Distributor.
                                      MisterCMK;209241 wrote:
                                      One word.
                                      Distributor.
                                      weak...
                                      • fdfreakF Offline
                                        fdfreakF Offline
                                        fdfreak
                                        That sucks man. Sorry to hear about that.
                                        • BuniqueB Offline
                                          BuniqueB Offline
                                          Bunique
                                          Welcome to the forum. Nice car.
