Borg Warner Goodness
sweet!
Grr;209410 wrote:
Im thinking you should have went with the new 1.1 a/r turbine housing. So its availible if you wind up needing it.
GaryI didn't want the smaller housing because my car is used more for drag than street. I have the direct port to spool it on street anyway.
I'm not sure I follow you by going with a 1.10 a/r.....If I go with that size, I'll def need more, hence the 1.32 a/r that I went with.
Matt
well, i didnt know you were gonna spray that much, then it wont be a problem at all. I can tell you though, it wont spool for shit without it! How much was that anyway? and where did you get it from. Im thinking of doing the 80mm upgrade next year as well.
Also, is it a SX80, ST80 or regular S400 like i have?
Gary -
GaryI got it from SLS. It's called the S480, but it is in the S400 series. I'll be spraying a 155 shot to spool it.
