  3. Wanted Ads
  4. WTB HIDs
WTB HIDs
28 Posts 14 Posters 1.7k Views
    I know my hella headlights are not designed for HIDs. Do i have HIDs in them? NO. I was looking at getting PIAA HID driving lights for my jeep.
    There are alot of people that do HID retrofits in the Nissan world, maybe not the hondas.
    Projector or no projector, doesn't matter. A HID bulb does not stay in the same location as a standard halogen bulb, so the beam is not reflected in the spots it was suppose to.
      sorry to say no fog light housing is made for hids..... more than half the aftermarket projector housings out there are also not made for hids...
      Most people that do retrofit hids use tsx or s2k projectors as they are the best quality and easiest to retrofit.
      But anyways the way fogs are aimed and with the housings they have...the HIDS just light up about 10 feet in front of the car.
      But it looks alot better when you have HIDS headlights and fogs rather than hids headlights and standards fogs.
      • 9 Offline
        9 Offline
        94prelude
        • 9 Offline
          9 Offline
          94prelude
          ^^^ yup u got pm ridinrails
            Be careful when putting an HID bulb into a halogen housing. Like it has been said before, they are not designed for it and will glare like a mofo.
            • 9 Offline
              9 Offline
              94prelude
              thanks for the tip
              • Krazy_KlingK Offline
                Krazy_Kling
                so what exactly is required to put hids in any housing?
                Jordan
                02 CBR600 F4i
                96 Nissan 200SX
                90 Nissan Sentra
                87 Honda Helix
                > SPANISH-RICE;209867 wrote:
                  Not sure what you are asking....you can put them in whatever housing you choose (assuming it is the same bulb style as what you were replacing), but to have the proper lighting/cut-off, you should have housings that are specifically designed for HID's. Jim explains it better in the thread below:
                  http://fargostreet.com/forums/showthread.php?t=1919
                    Krazy_Kling
                    okay, lets say i purchased an HID kit and wanted to put them into a 300ZX. What are all the steps that i need to go through to 100% properly install them without glare, sharp cutoff, and especially keeping the housing safe. do i need to replace the housing itself? also the retrofitting......what is needed to do that and how is it done? I just want them done right the first time. Thank You all that help me out with my rediculous questions!
                    Jordan
                    02 CBR600 F4i
                    96 Nissan 200SX
                    90 Nissan Sentra
                    87 Honda Helix
                      You are very right, but most ppl are too ignorant to believe that u should retrofit them to actually make them work the way they are supposed to....
                        thrash
                        Actually, Hella (German lighting manufacturer, OEM equipment on most high end German cars) makes HID fog units. The Micro DE fog assembly comes in HID and non HID versions.
                        http://www.rallylights.com/hella/Micro_DE.asp
                        Retrofitting HID bulbs / systems into optics & housings not designed for them is stupid. Don't do it.
                          DO SOME RESEARCH.
                          Type in HID retrofitting in google and you will have more articles than you need.
                          • FG2F Offline
                            FG2F Offline
                            FG2
                            http://www.piaa.com/Lamps/Lamps-HID.html
                            :stirpot:
                              PWNAGE!
                              I was going to post them, but got to lazy.
                                KA-T_240;210902 wrote:
                                PWNAGE!
                                :stirpot:
                                ownage?
                                I know they make aftermarket hid fogs....i was talking oem...
                                although some cars do have factory fog hids im sure, but i dont care to reasearch them.
