  3. Run Your Mouth
  4. Joels properly set welder VS Mine........
54 Posts 23 Posters 5.4k Views
    Pwn3d!
    Your penetration skillz are next to none.
      Zach, I'm beside myself with your amazing feats of penetration.:woot:
        thurmanmerman;211279 wrote:
        No pics of the settings of the welder? I call fake.
        I dont know what else you want me to do, the other machine is smaller and has lighter wire and would of done a better job than this one even
        Just wanted to show the forum members that GMAW (MIG) weld leaves a very nice weld without spatter when set and executed properly
        Its alright you too have welding envy...... even with a simple of process of GMAW
          zac is the god of welding, next to my boss, but thats not the point. Point is he made a clearly informative post and had very obvious results. ZBrown>all, end of story
          BTW, zac is the best there is at penetration, ive seen it first hand 😉
            Here is to Zac not having to blow some dude... haha.
              BTW, zac is the best there is at penetration, ive experienced it first hand 😉
              Fixed....
              Hey zach, I didn't ask you to do it with your welder, I said weld with my welder on the same material. Why a SMALLER MACHINE make it easier? Why is there porosity in your first weld? I thought you were l33t?
              If you want me to post pics from work welding with proper equiptment, I can do that!
                Also, Just because you "manipulate" or as it is called in the industy oscilate, more doesn't mean it is proper, or a stronger weld... Also, Triggering with my welder would never penetrate. And triggering is NEVER as strong as actually welding in a continuous pass. It is used to fill in gaps where heat would burn holes through the pipe. Also, Why don't you try welding a bead longer than 2 inches?
                  Also, that plate looks kinda greasy, any chance you sprayed that down with antispatter before you welded? 🙂
                    Sweet triple posts.
                      OH you have so much to learn..........I could rip apart everything you just said there but i wont, because i like it when you talk out your ass........ and sound ignorant as fuck
                      One thing i will say is you are totally in left field with triggering not penetrating..........
                      Your welds look like ass, i just wanted to point it out, I guess if you dont understand how the process even works how can i expect you to adjust the machine to not look like bird do do
                      I welded those three beads on that one piece because that is what i mocked up in 5 mins,
                      Your welds are bad/shit, just end your rant
                      I could flux core a bead with no shielding that looks better than what you had on there
                        yep sure did 😕
                        Dude stop, you are looking worse and worse
                        the pics speak for themselves
                          You going out of your way to show everyone how much better you are than me looks 10 times better? right. take the challenge next time you are in fargo... or don't talk smack. > zbrown;211301 wrote:
                          prove it
                            LOL at Haterade Joel. Dude, you posted up pics, and it looked like dogshit. Thats the reality, deal with it. Sure you can weld better at work, but you didnt post up pics of that so STFU. Zac doesnt need to do a weld longer than that, he proved his point and i could guarantee that hes not pulling some shady shit like spraying it whith spatter sheild, hes better than that.
                            Dude, you got pwned, accept it and take it like a man, no big deal it happens to everyone once in awhile. Honestly, when you posted those pics up, i thought to myself, those look worse than some shit i do, and i simply dont give a fuck what my welds look like alot of the time.
                            BTW, a correctly set welder will not leave spatter, my boss has 30 years in the field professionally, he told me so.
                              ^6 ft, 1 pass, no starts/stops
                                prove it
                                Ah this is so fun, I would love to stay up and relish in this but the woman is here so i say bedtime.........
                                unfortunately joel you will be up all night worrying about getting owned on a forum and eventually rubbing one out tonight
                                  whats with the personal attacks? Who looks bad now. Why don't you critique those ones zack, what it set wrong? too much spatter?
                                    Good job, those look nice. Its a real benefit to work with nice clean metal with good gaps and stuff, man i hate welding on rusty old farmer shit.
                                    BTW, good story here. One day i had to weld in this chemical tank, aluminum with the spool gun right. Anyway theres only a big enough hole to get your torso through, and it was a 16ft tank, welding was on the baffles inside. I had to hang the from forklift by my feet while holding the gun and cables, 20ft in the air and get set into this thing. Aside from the stink, the shit burned your skin as it was in direct sunlight and about 90 degrees and humid that day. I thought, WTF is this shit anyway, especially getting jerked around on this fuckin forklift you know? So i had to do this shit for 30-40 minutes and it sucked balls, but i ended up making a couple hundred in cash on the deal.
                                    So, if you ever think you have it rough, think again
                                      thrash
                                        thrash;211312 wrote:
                                        LOL!
                                          Hey parker I just remembered something, that spool of wire was on its last leg, the un-evenness(word?) of wire coming out could have caused the spatter...
