  4. Computer help
Computer help
5 Posts 4 Posters 718 Views
  • NickBN Offline
    NickBN Offline
    NickB
    So a while back I tried booting up my desktop and got no display. Bought a new video card because I tried the old one on a different monitor and it still didn't work. Put the new video card in a got no display again. Computer boots up, fans all go and still nothing....any suggestions?
    • JohnWJ Offline
      JohnWJ Offline
      JohnW
      reread your thread a few times, nevermind what i said previously.
      if you don't get any beep codes on power on self test (POST) but you don't get any display even on a known good monitor, I would suspect the video bus has gone south. you can try the old video card in a known working computer, but if it works or doesn't, chances are the video bus on your PC is bad. try the new video card on another computer too just to be sure, it probably works, but you never know. in any case you are going to need a new motherboard, and I would replace the power supply as well, as a common cause of video card failure is bad voltage (can cause overheating, etc).
      werd
      90 Civic DX hatch
      D16a6/y8 mini me
      • NickBN Offline
        NickBN Offline
        NickB
        Hmm well the power supply is brand new also, ill have to try it in a diff mobo I guess, ugh..
        • L Offline
          L Offline
          Link
          Banned
          whats the new vid card?
          i had a problem when i bought my 8600 gts that I had to flash my bios to a newer version so that it would be compatible with the 8600.
            Is there an onboard videocard as well? If so, perhaps it is set to default?? (I haven't owned a mobo w/ an onboard card in years....can't remember what has to happen for it to work w/ an outboard card)
            Also, might be worth resetting the cmos (should be a jumper on your mobo somewhere)...find out what MOBO you have and check its reset instructions.
