  4. Status of your project car...
40 Posts 29 Posters 2.0k Views
    The one is waiting on the tranny to come back then install it with new clutch/flywheel/driveshaft, hood/hood pins, then for some Weld draglites, and then new tuning stuff. There are others...
    Other waiting on flywheel to get done at machine shop so I can put tranny on and drop in motor. Then We can attack the HUGE wiring mess from a shitty alarm(can't even turn the key on with the alarm in the car, it just goes off) and stereo install. Then fix what ever other problems we find, PDR, and then getting it cleaned.
    • GnArKiLlG Offline
      GnArKiLlG Offline
      GnArKiLl
      i just finished putting the motor together for the talon. ill do the timing and drop it in should be done next weekend
      1976 Chevy K5- lifted beater
      • Afsil80A Offline
        Afsil80A Offline
        Afsil80
        Mine was running, then blew the HG. It blew off a coolant hose, turns out the fitting was rusted and had no bead roll WHATSOEVER. Dumped all coolant, and you can guess the rest. Stout motor though, I won't go into details on how far she drove because it proves that I mis-read what had happened.
        Now it's 100% torn down, main/rod bearings/rings/gaskets/seals ALL arrive tomorrow, rotating assembly gets put back together tomorrow, gasket/seal on Thursday along with head and manifolds.
        Should be running Thursday night, break it in, clutch is broken in, so that's good to go; leak check.
        Friday, drive to work, take on interstate; leak check.
        Saturday, 2 hr drive to Atlanta for NHRA Sport Compact weekend.
        That being said, I don't see an option that suits me...make a 'Was done, blew it up already, almost ready again' and I'll vote...
        -Peter
        1991 240SX
          Ya, I realized I forgot a halfway one right after I hit submit...lol
            LOL, CA18 FTMFL man, shoulda stuck with the KA, wouldnt have those problems, haha. Dont worry though, i had to re-do shit twice too this month, fuckin pissed me off.
              judt eiting on my godamn turbo to get here in the mail then im mobile again. F'n A cotton
              • Afsil80A Offline
                Afsil80A Offline
                Afsil80
                Fuuuuck the KA.
                Worthless ass motor. The ONLY reason the CA is in this car is because the KA crapped out on me. And I am pretty happy with how the CA handled the overheating by only nuking the head gasket. Only blew out one chunk by a water port in between the #3 and 4 cylinders. It was a factory gasket, too.
                Hell, compression numbers for all 4 cylinders was still within specs, aside from the +/- 15 difference between #1 and 2.
                Numbers were 160, 145, 142, 142. Minimum is 140, so I said 'fuck it, do it now, save another headache later.
                Block was hot tanked, honed, decked; head was resurfaced, and got a mild port and polish.
                But now...Cometic 2mm + ARP studs, ARP flywheel bolts, deleted butterfly valves, ACL race bearings (main and rod), OEM piston rings, all new seals, gaskets, hoses, O2 sensor, thermostat, etc.
                I'm not cutting corners this time. Lesson learned, haha.
                -Peter
                1991 240SX
                  did you get your block and head properly decked for the cometic? Do not want more leaks
                    Depending on which stage of my project you are talking about I'm either almost done or barely started. Basically, I need a new BOV and a good tune on the dyno and I'm set w/ the current motor setup. My 2nd motor is nearly complete, just awaiting cams and a good P&P on the heads....but I really don't want to install that until I get to the next phase involves a different transmission as well as a new rear end and drive shaft...and I've barely started even thinking about that yet.
                    • JohnWJ Offline
                      JohnWJ Offline
                      JohnW
                      mines on going. i cant do anything that will have her down for more than a day or two so im stuck that way. system and alarm going in this week, valve train getting adjusted and gone over more than likely this week as well. plans for this spring/summer include suspension, brakes, wheels, tires, prolly just a cam instead of the mini-me for now.
                      90 Civic DX hatch
                      D16a6/y8 mini me
                        well, i stripped my crx down to a bare shell. then i striped my rhd front clip. and 2 tyrs later thats about it.... hahah
                        mine will be done when hell freeze's over.
                        • ruthless351R Offline
                          ruthless351
                          just waiting on the gears and intallation kit and im ready to put it all together.
                            still waiting on my fuckin steering that i ordered in january. Other than that, need to order the 9" and install, possible shorten driveshaft, some wiring for the fuel pump and sub. In front, finish assembling the engine/trans and set it in, weld the wastegate on and make a downpipe. Not much, hopefully it will be done by may.
                              You forgot about all the ICE!!!
                              **My car is stored/parked now.
                              Contemplating fixing ALL the petty imperfections with the Miata I/E: strut mounts, mirrors, paint imperfections, etc. Maybe doing some performance stuff as well.**
                              • wa2fastcamaroW Offline
                                wa2fastcamaro
                                I was hoping to have my fiero done by the topper car show, but no such luck. I need about another grand in parts and with the wife not working paychecks do not go far. So I took up doing automotive work in my spare time, and advertised on craigslist. Now I am 3 weeks behind on automotive work. Everyone hit me at once with major work so now I am working a extra 30+ hours a week at my home shop fixing cars. And with the extra money now I am buying more shop equipment instead of parts for my projects.
                                Plus I have bought a couple more projects here and there like a bandit trans am.
                                Boys and Their Toys Auto
                                Phone: 701-371-5615
                                E-mail: [email protected]
                                • 99civic9 Offline
                                  99civic9 Offline
                                  99civic
                                  mine is never done still finding the right parts for it and waiting to paint it soon.
                                  2000 civic SiR - jdm sickness
                                    ^Boost?
                                    • 3_Series3 Offline
                                      3_Series3 Offline
                                      3_Series
                                      Project cars cost too much money. 🙂
                                      2002 Subaru Legacy
                                      1993 BMW 325i (sold)
                                        in the paint booth, Suspension is in the mail, Interior is in a box, waiting for the car. Shutt auto steering wheel, pedals and shifter are in the mail. Would be boosted but I bought this damn TV...
                                          I bought a house thanks to Bjornstad so my project has yet to begin. Oh and the integra is way on the side burner now. Home ownership > cars.
