  4. Status of your project car...
40 Posts 29 Posters 2.0k Views
    Afsil80;211396 wrote:
    Mine was running, then blew the HG. It blew off a coolant hose, turns out the fitting was rusted and had no bead roll WHATSOEVER. Dumped all coolant, and you can guess the rest. Stout motor though, I won't go into details on how far she drove because it proves that I mis-read what had happened.
    Now it's 100% torn down, main/rod bearings/rings/gaskets/seals ALL arrive tomorrow, rotating assembly gets put back together tomorrow, gasket/seal on Thursday along with head and manifolds.
    Should be running Thursday night, break it in, clutch is broken in, so that's good to go; leak check.
    Friday, drive to work, take on interstate; leak check.
    Saturday, 2 hr drive to Atlanta for NHRA Sport Compact weekend.
    That being said, I don't see an option that suits me...make a 'Was done, blew it up already, almost ready again' and I'll vote...
    Ya, I realized I forgot a halfway one right after I hit submit...lol
      LOL, CA18 FTMFL man, shoulda stuck with the KA, wouldnt have those problems, haha. Dont worry though, i had to re-do shit twice too this month, fuckin pissed me off.
        judt eiting on my godamn turbo to get here in the mail then im mobile again. F'n A cotton
        • Afsil80A Offline
          Afsil80A Offline
          Afsil80
          Fuuuuck the KA.
          Worthless ass motor. The ONLY reason the CA is in this car is because the KA crapped out on me. And I am pretty happy with how the CA handled the overheating by only nuking the head gasket. Only blew out one chunk by a water port in between the #3 and 4 cylinders. It was a factory gasket, too.
          Hell, compression numbers for all 4 cylinders was still within specs, aside from the +/- 15 difference between #1 and 2.
          Numbers were 160, 145, 142, 142. Minimum is 140, so I said 'fuck it, do it now, save another headache later.
          Block was hot tanked, honed, decked; head was resurfaced, and got a mild port and polish.
          But now...Cometic 2mm + ARP studs, ARP flywheel bolts, deleted butterfly valves, ACL race bearings (main and rod), OEM piston rings, all new seals, gaskets, hoses, O2 sensor, thermostat, etc.
          I'm not cutting corners this time. Lesson learned, haha.
          -Peter
          1991 240SX
            did you get your block and head properly decked for the cometic? Do not want more leaks
              Depending on which stage of my project you are talking about I'm either almost done or barely started. Basically, I need a new BOV and a good tune on the dyno and I'm set w/ the current motor setup. My 2nd motor is nearly complete, just awaiting cams and a good P&P on the heads....but I really don't want to install that until I get to the next phase involves a different transmission as well as a new rear end and drive shaft...and I've barely started even thinking about that yet.
              • JohnWJ Offline
                JohnWJ Offline
                JohnW
                mines on going. i cant do anything that will have her down for more than a day or two so im stuck that way. system and alarm going in this week, valve train getting adjusted and gone over more than likely this week as well. plans for this spring/summer include suspension, brakes, wheels, tires, prolly just a cam instead of the mini-me for now.
                90 Civic DX hatch
                D16a6/y8 mini me
                  well, i stripped my crx down to a bare shell. then i striped my rhd front clip. and 2 tyrs later thats about it.... hahah
                  mine will be done when hell freeze's over.
                  • ruthless351R Offline
                    ruthless351
                    just waiting on the gears and intallation kit and im ready to put it all together.
                      still waiting on my fuckin steering that i ordered in january. Other than that, need to order the 9" and install, possible shorten driveshaft, some wiring for the fuel pump and sub. In front, finish assembling the engine/trans and set it in, weld the wastegate on and make a downpipe. Not much, hopefully it will be done by may.
                        You forgot about all the ICE!!!
                        **My car is stored/parked now.
                        Contemplating fixing ALL the petty imperfections with the Miata I/E: strut mounts, mirrors, paint imperfections, etc. Maybe doing some performance stuff as well.**
                        • wa2fastcamaroW Offline
                          wa2fastcamaro
                          I was hoping to have my fiero done by the topper car show, but no such luck. I need about another grand in parts and with the wife not working paychecks do not go far. So I took up doing automotive work in my spare time, and advertised on craigslist. Now I am 3 weeks behind on automotive work. Everyone hit me at once with major work so now I am working a extra 30+ hours a week at my home shop fixing cars. And with the extra money now I am buying more shop equipment instead of parts for my projects.
                          Plus I have bought a couple more projects here and there like a bandit trans am.
                          Boys and Their Toys Auto
                          Phone: 701-371-5615
                          E-mail: [email protected]
                          • 99civic9 Offline
                            99civic9 Offline
                            99civic
                            mine is never done still finding the right parts for it and waiting to paint it soon.
                            2000 civic SiR - jdm sickness
                              ^Boost?
                              • 3_Series3 Offline
                                3_Series3 Offline
                                3_Series
                                Project cars cost too much money. 🙂
                                2002 Subaru Legacy
                                1993 BMW 325i (sold)
                                  in the paint booth, Suspension is in the mail, Interior is in a box, waiting for the car. Shutt auto steering wheel, pedals and shifter are in the mail. Would be boosted but I bought this damn TV...
                                    I bought a house thanks to Bjornstad so my project has yet to begin. Oh and the integra is way on the side burner now. Home ownership > cars.
                                    • 99civic9 Offline
                                      99civic9 Offline
                                      99civic
                                      KA-T_240;211414 wrote:
                                      ^Boost?
                                      some day!!!
                                        The stage ur planning on finishing first, lol... I know what u mean Im doing "stage 1" right now...prob got a few more to go over the years...
                                        • Afsil80A Offline
                                          Afsil80A Offline
                                          Afsil80
                                          No, I actually decided to make the surface as rough as sandpaper.
                                          Doosh. 😛
                                          Haha, this kinda sounds like my friend Matt. Has everything in the world to make a hatch or Integra run 10's in his garage. But no car to put it all into, haha.
                                          Now he bought a house, and says he'll get the car once he has the funds again.
                                          -Peter
                                          1991 240SX
