  4. Is there 93/94 octane anywhere in FM area?
24 Posts 20 Posters 1.2k Views
    Havent been out there for a while, but the Gas station on walstreet in N. Moorhead used to sell 92oct. non oxygenated.
    Bradys/Clark has 92.5 but is ussually WAY more then anywhere else.
    There is still a BP in moorhead.
      thrash
      Can you still get a drum of toluene from sherwin williams? If so, you can blend it with 91 to get any octane you like.
      Not exactly what you want but it may be the best/cheapest alternative.
        What used to be a BP off of 25th street and I94 sells 92
        • BlueSRT0483B Offline
          BlueSRT0483
          What about the gas station in way W. Fargo on Main that used to sell 93? Did they drop down to 92???
          2004 Dodge SRT-4
          ...Formerly "A853"...
          • RaiderR Offline
            RaiderR Offline
            Raider
            they dropped there 93 also...I just get 91 and run Torco in my truck
            POWERD BY
            • JN210J Offline
              JN210J Offline
              JN210
              What is the best mix of gas and other product for power?
              *1989 Nissan 300ZX Z31 *
              > DelSlow;262050 wrote:
              > I like the new JN210
                Nitrous Duh
                  like mix it just to make more power? nothing will give you more power just by mixing it with fuel. run 85.5 octane and let it detonate, that much cylinder pressure is sure to up your power a little
                    to answer your question, No, there isnt anyplace in town that sells 93/94.
                    The Gas station in w.Fargo on main ave used to, but now they dont even carry 92.
                    The Old bp that is on 25th right off of 94 Has 92 but i wouldnt suggest getting gas from there.
                      you guys do realize that when it says 91 octane. its says minimum right above it.... so its not just straight 91 octane... it could be higher, the sticker just says that it meets the minimum 91 octane rating...
                      • FG2F Offline
                        FG2F Offline
                        FG2
                        Truth...I just read an article on MON and RON ratings. Here's part of the article (taken from Sept 2003 TURBO magazine):
                        "If you have 2 fuels with the same AKI or octane, look at the RON and MON numbers. Let's say one fuel has a RON of 118 and MON of 104 (so 118 + 104 / 2 = AKI octane rating of 111), and another fuel has a RON of 112 and MON of 110, both yield an AKI of 111. The fuel with the higher MON number will generally tend to perform better in high-rpm or racing conditions..."
                        ...the "91" or "92" is an average of the MON and RON values. So keep that in mind while reading below/above the big "91" rating into the fine print.
                        • M Offline
                          M Offline
                          musthavemuzk
                          there is fine print there?
                          will have to look next time.
                          the former BP here in TRF officially changed signs and such this week. so they no longer carry 92 non-oxy. just 91. that is now a tesoro station.
                          the former BP in erskine also no longer carries 92 non-oxy. it is 91.
                          will see how car acts with this tesoro in it. been running 92 or 92 non-oxy in it since i got it in june.
                          Monty
                          14.59 at 94.85 still stock
                          www.pbase.com/musthavemuzk
                          • FG2F Offline
                            FG2F Offline
                            FG2
                            Monty
                            Well according to the article there is values for RON and MON at the pump...But tonight I went pioneering to try and find 92, and the only station I found with it, was the one RidinRails mentioned off I94 and 25th. I didn't see any fine print at any of the stations I checked out....So perhaps this information is no longer public (article was from 2003?!?)
                              is there a way to talk to the stations about there gas? like a manager or higher up?
                                1 part 91 octane, 2 parts diesel fuel (make sure it's off road use, the red dyed kind), and 1 part of rabid coon urine...
                                  rabid coon urine! fuck i knew i forgot something!
                                    2% gasoline and 98% ethanol...or so I'm told anyway.
                                      No shit, we would be their best and most loyal customers
                                      • FG2F Offline
                                        FG2F Offline
                                        FG2
                                        Someone go hit up the gas station manager and ask for gas specs!
                                        • M Offline
                                          M Offline
                                          musthavemuzk
                                          could be could be.
                                          i have been talkin with a few ppl up here and with the BP now tesoro and no longer carrying 92 non-oxy gas i am trying to make time to get in touch with more ppl. i am not a snowmobiler but keep hearing that many of the performance sleds need 92. so with no 92 in town it sux for them as well as for myself as well as the hot rods and street rods....
                                          so we are gonna see what we can come up with.
                                          Monty
