  4. Project: putting a real motor in a RX-7
79 Posts 24 Posters 4.2k Views
  • z31Z Offline
    z31Z Offline
    z31
    :nonono: Here is a clue. :icon_scratch:
      i was sneaky and just stole a cam on ebay at the last second :).... I just dont know where a camshaft goes..... whatever that is
      • z31Z Offline
        z31Z Offline
        z31
        Magic stick? :icon_scratch:
        • z31Z Offline
          z31Z Offline
          z31
          This is the intake manifold.
          Edelbrock Victor Jr LS EFI :icon_cheers:
            happy pants once again !
              mmmmmmm, thats sexy! Now if i would just post up pictures of that nice cam i have sitting here...
              • ChristianC Offline
                ChristianC Offline
                Christian
                What is the specs of the cam?
                Playtime Performance
                06 F-150 Lariat
                  Its a comp XR265
                  212/[email protected]
                  .525 lift
                  114 LSA
                  Not very big, but should be pretty much perfect on a 4.8, and more so as a turbo cam.
                    Got some accomplished today. Cut 1.7" out of the oil pan and welded back together, installed the cam, and Jason got the black sprayed on the motor and trans.
                      That's cute.
                      • 94NDTA9 Offline
                        94NDTA9 Offline
                        Who's building the tranny?
                          i dont think this trans will have alot of problems holding. sure it will need it eventually, but with zacs 2600lbs, and 4.11 gears, there shouldnt be much stress on it. maybe this winter it will get a mild stall and a shift kit, new clutches, but thats pretty much it.
                          As a matter of fact, BMR Fabrication took a bone stock 4l60 in a 04 GTO down to a 10.2@130 before it started slipping, in a car with a 3900lb raceweight. So 10.0s in a 2600lb car should be a cake walk
                            wow good work you two 🙂
                            man with the intake mani and valve covers the color of the car that is gonna look sick....... i
                              oh and using the new edelbrock cast intake elbows that just came out instead of a sheet metal one
                              really low profile, clears a stock hood..... like this, but powder coated black
                              • 94NDTA9 Offline
                                94NDTA9 Offline
                                I see. Good luck with that. It is kind of hit or miss, some people do well, but most end up needing a rebuild sooner than they would like.
                                Also, isn't it technically a 4L65E?
                                • z31Z Offline
                                  z31Z Offline
                                  z31
                                  Did some painting today. :icon_santa:
                                    so zac when is the turbo going on?
                                      ..... nice rattle can job!
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        I placed those rattle cans on the table as a decoy. I got u Faber.:icon_cheers:
                                          when ever you want to do the hotside sexy like 🙂
                                          getting a different rad and putting it way up front.....
                                          so we will have like 1 foot between the engine and rad to stick something
