  4. FS. Rx7 TII tranny and custom driveshaft TII--> na
5 Posts 3 Posters 705 Views
    yeah seeing if any of you FC guys up there would be interested
    got my TII transmission and a custom drive shaft that will allow you to use the TII transmission with the NA rear with no other mods needed
    The drive shaft is super heavy duty (3" i believe)and has greaseable and replaceable U-joints.............. un like the stocker
    mazda trix sells this for $300 alone
    tell you what, i will give you a TII flywheel, stock clutch, TII starter, TII tranny, and the driveshaft for $350 total
    so a direct bolt in swap............. this will bolt right up to your NA engine as long as you use the TII flywheel
    yeah so this is dirt cheap but i want it all out of my garage........ coming up to fargo within the next week so let me know
    I know there are a couple NA fc guys that could benefit from a beefed up drivline and especially tranny doing your drifto 😉
    um I will throw in a master and slave clutch cylinder with SS braided line instead of teh gayness OEM steel+rubber line
    have a NA 5speed too here
      Damn that would be nice! now only if i had money! ill ask almer for ya!
      • 7ormore7 Offline
        7ormore7 Offline
        7ormore
        My friend might want it we're starting the N/A to TII swap this weekend
          well i am leaving for fargo by 1 pm central today
          so if someone wants this stuff they need to get r done, or it will all lay here and not up there 🙂
            I dont really care someone just make an offer on what $$ they have right now
            i want it out of my sight
