  4. Smokin this afternoon.
21 Posts 11 Posters 955 Views
  • JN210J Offline
    JN210J Offline
    JN210
    I know....Im actually thinking it might be easier to just buy a CF hatch and new glass....although, the window is fine...I just need the time...or money.
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
    • capitljC Offline
      capitljC Offline
      capitlj
      taking it off just takes time. not that much really quit being lazy and just pull it off. Nice work on the nightshades that stuff works pretty good doesnt it.
      > Mitch Hedberg wrote:
      2004 Impala LS 3.8
      • JN210J Offline
        JN210J Offline
        JN210
        Yeah it does, I think im gonna see what I cant do about it pretty soon here.
          A CF hatch would not really be worth the money. You also need to use a lexan or plastic window when using a CF hatch, as glass is to heavy. For some glass works, for others....... not so much.
          Go to the junkyard, find a hatch off of another z31 with no tint. Remove and purchase the hatch w/ glass. Then bring it to the glass shop and have the glass swapped out.
          • G Offline
            G Offline
            GoldyHatchPSI
            Remove the tint with a heat gun. Then use steel wool and some glass cleaner or alcohol to remove the glue.
            • JN210J Offline
              JN210J Offline
              JN210
              so....heat the tint....and peel off with a razor right?, Ive been doing that, I now have my car in the garage...thank god....cant stand for it being a lawn ornament..I started on removing the tint today....might be done sometime next weekend.
                I'd lay money that he fucks up the defrost lines.
                  Who cares, if you don't drive the car in the winter, peel it all off.
                    the older cars defrost lines suck ass and if the tint has turned purple i feel sorry for him! that is going to suck balls! it would almost be better to just buy a new back window!
                    • JN210J Offline
                      JN210J Offline
                      JN210
                      It has indeed turned purple....and yes, it DOES suck balls...but im not going to give up, The glass is perfectly fine, its the shitty tint that needs gone...I dont care if it takes me forever.
                      • C Offline
                        C Offline
                        CivicEX7777777
                        I would offer my assistance, but i work all weekend.....
                        2007 Pontiac G5
                        2007 Yamaha C3
                        2002 Oldsmobile Alero
                        1994 Nissan Sentra
                        • JN210J Offline
                          JN210J Offline
                          JN210
                          thats ok, I am gonna be in fargo most of this weekend....job searching...
                            You WILL ruin your defrost lines. No way around it.
                            Either do the junk yard glass trick, or start scraping away. What works good for the door windows, is to remove them from the car and use paint and decal remover.
                            • GoodnbuzzdG Offline
                              GoodnbuzzdG Offline
                              Goodnbuzzd
                              go to an auto parts store and get some 3m adhesive remover and rub it on with a rag and let it soak for a few minutes, then go to work, you should not need a razor.
