  4. cd player wiring
cd player wiring
8 Posts 5 Posters 818 Views
  • black2gB Offline
    black2gB Offline
    black2g
    i'm wiring up a cd player to a 12v bat. i beleive there is only 2 power wires. (ign and B+/mem) what needs to be fused? And I just give it power and ground, hook up speakers right? Is it that simple. and also what size fuse? Its just a old kenwood i think. Thanks
    1995 Eagle Talon
    2000 Doge Neon
    1974 Porsche 914
      yellow & red need power, black needs ground. Some decks come w/ inline fuses already, others don't. The only real way to answer what size fuse is needed is to identify the model number and then look up an owners manual. If it's just on a battery on a bench, you probably won't "need" fuses...but never a bad idea to use them...
        There should be a fuse in the back of the cd player itself. If not, then at least the red (12v acc) needs to be fused for safety. I'd run them both fused if that was the case. usually 10-15 amps is the norm. The memory hardly draws anything so just what the red wire draws which is usually less than 10 amps unless your working the fooey out of it.
        • blackcherryTSiB Offline
          blackcherryTSi
          Yea ive dont it just red, black, and speakers... I didnt have a fuse with my setup
          1995 Honda Civic
          • black2gB Offline
            black2gB Offline
            black2g
            ok thanks. yeah i'm wiring it up for a fish house. i'll post some pics maybe after we get the speakers and stuff in.
            1995 Eagle Talon
            2000 Doge Neon
            1974 Porsche 914
            • black2gB Offline
              black2gB Offline
              black2g
              heres some pics.
              1995 Eagle Talon
              2000 Doge Neon
              1974 Porsche 914
              • xtreamedrtbkerX Offline
                xtreamedrtbker
                All the welding I did on that thing was worth it cause that looks awesome.
                Living it up in Phoenix....[SIGPIC][/SIGPIC]
                • black2gB Offline
                  black2gB Offline
                  black2g
                  thanks man. you did a good job.
                  1995 Eagle Talon
                  2000 Doge Neon
                  1974 Porsche 914
